Home > Technical (L322) > Rear door Rubber window trim / finisher
dazza1983
How do you replace the window trim / finisher on the rear door window ??
I noticed that somebody has once before replaced the rear left one but when they fitted it, it seems that they never quite went forward enough and the cut outs are not lining up properly.
Just so we talking about the right thing it’s this
 Regards
Daz
2011 (61plate) 4.4 tdv8
sumatra black
previous cars
e46 m3
e53 x5
Post #514802 9th May 2019 7:19pm
Highroller
United Kingdom 2005 Range Rover Vogue SE 4.4 V8 Java Black
It does look as though it could go forward a little. They are quite a tight fit length way. They just pull up & can be pushed back down, so you could have a go at realigning it.
Just replaced mine, easy to do but expensive.
They tend to corroded from the inside & then you see them start to splay out. They average out between £50 - £60 each & put a little petroleum jelly on the door flange before refitting the moulding (just keeps the water out a little longer). Thumbs Up
Post #514816 9th May 2019 8:47pm
dazza1983
Anyone got the part number for these ? Regards
Daz
sumatra black
previous cars
e46 m3
e53 x5
Post #514823 9th May 2019 9:32pm
BMG
United Kingdom 2002 Range Rover Vogue 4.4 V8 Bonatti Grey
Interesting. So with plastic trim tool, they will just pry upwards and off ?
Mine has two bubbling tatty door trims on the n/s I'd like to do.
Post #514825 9th May 2019 9:54pm
dazza1983
Yeah just played with mine. Although now I want to replace it. So any part numbers would be great??
So the just pry up with trim tools and push back down.
The door has a metal ridge built into it and the trims push down onto this ridge. Regards
Daz
sumatra black
previous cars
e46 m3
e53 x5
Post #514826 9th May 2019 9:56pm
Highroller
Daz, You need to check Microcat for the part No's as mine was 2006 & the part Nos were superceeded.
BMG, If yours are bubbling then they need replacing. Yes they come off with a plastic tool, but I would wait until you have new ones to go back on, as the originals may not sit back correctly.
Post #514827 9th May 2019 10:12pm
dazza1983
What’s microcat buddy? Regards
Daz
sumatra black
previous cars
e46 m3
e53 x5
Post #514830 9th May 2019 10:26pm
Bushy30
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
try CGE500720 Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
2004 FFRR Vogue 4.4 V8 with LPG
1997 P38 4.0 SE with LPG
1997 P38 4.6 Vogue with LPG
Post #514831 9th May 2019 10:33pm
Highroller
Microcat is the online parts catalogue.
You can down load it from the Wiki. It's a Russian site, but translated into English. Thumbs Up
Post #514850 10th May 2019 9:47am
