![]() | Home > Maintenance & Mods (L322) > hawkeye to buy or not to buy |
| MikeO Member Since: 02 Jan 2018 Location: The Cotswolds Posts: 548
Do you have the i930 or the i980 (just checking it isn't a typo). My quick search shows the 980 as a Mercedes reader so it may only show generic OBD codes for other makes. My i930 while not as capable or easy to use as as my IID tool will give you the specific error code as is a dedicated LR reader. 2016 Skoda Octavia VRS Estate
| knares Member Since: 22 Jun 2017 Location: Perth WA Posts: 836
yes you are right, i just corrected that.
Do you get a specific fault code? 2016 Skoda Octavia VRS Estate
| Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6434
If you are planning to keep the car, or stick with Range Rovers / Land Rovers - then iiDTool / AllComms (for your current model) is the way to go. If not then the more generic tools like Hawkeye / Solus / Autologic may solve most issues. .
no i dont think i do, i wrote all the fault codes down for the ABS but i haven't got one wrote down for that RR 2005 4.4 petrol Any spelling mistakes are the fault of spellchecker Previous MG J2, CITROEN light 15 x 2 gone unfortunately Present MERC 180e, RANGE ROVER L322, JAGUAR XJS, MERC 280SE, MG F, JAGUAR S-Type 6v 2003, jaguar s-type 8v 2004, Ford Cougar |
at this stage, yes, i do plan to keep the car RR 2005 4.4 petrol Any spelling mistakes are the fault of spellchecker Previous MG J2, CITROEN light 15 x 2 gone unfortunately Present MERC 180e, RANGE ROVER L322, JAGUAR XJS, MERC 280SE, MG F, JAGUAR S-Type 6v 2003, jaguar s-type 8v 2004, Ford Cougar |
In answer to your question, I don't think the IID can give you any more info on an error code than the i930. The IID is far more capable and definitely worth the money but I'm not sure it will help you isolate this particular problem. 2016 Skoda Octavia VRS Estate
| Bushy30 Member Since: 03 Jun 2018 Location: Powys Posts: 1102
You'll need to fix the canbus issue first Current: 2011 FFRR Vogue SE 4.4 TDV8
Hmmmmmmmmmmm RR 2005 4.4 petrol
| Essex1959 Member Since: 21 Feb 2019 Location: Wales Posts: 20
Take a look here https://www.rswsolutions.com/index.php/mki...-bus-fault it may help |
thats interesting.
I reckon that will be the solution |
hears hoping RR 2005 4.4 petrol
| All times are GMT |
