![]() | Home > Maintenance & Mods (L405) > Front brakes squealing under slow braking....... |
duckworthparts Site Sponsor Member Since: 30 Jun 2011 Location: Market Rasen, Lincolnshire Posts: 5217 ![]() ![]() |
What brakes did you fit? You can paypal direct using - www.paypal.me/duckworthparts
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3561 ![]() ![]() ![]() |
I would question the fitting and not the pad - squealing is usually due to lack of grease on the back of the pad.
CUE99T Member Since: 02 Oct 2011 Location: Glasgow Posts: 779 ![]() ![]() |
I fitted Brembo brakes with the same part number from JLR on the website Eurocar parts part numbers - not sure if they are the same elsewhere PADS - 10167027A DISC - 10467037A PAD KIT - 107670188 all smug in my new plug! 2021 Westminster Black D300 2013 Vogue SE - gone Some Porsche Cayenne guff pretending to be a 4x4!! 2006 Vogue 2004 Vogue 2001 Vogue |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35871 ![]() ![]() |
there have been many threads re the pros and cons of fitting aftermarket pads....i personally would only fit OE.. |
These are OE pads....its what are used on JLR dealerships.....I even checked the part numbers with Taggarts and Brembo website and ECP. all smug in my new plug!
brembo dont actually make pads....unscrupulous peeps use their brand name...
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1881 ![]() ![]() |
There is a TSB for squealing brakes. Involves filing a 45 degree angle into the top edge of each brake pad |
