![]() | Home > Maintenance & Mods (L322) > Headlight washers |
Laurie915 Member Since: 11 Sep 2011 Location: Canberra Posts: 72 ![]() ![]() ![]() |
Have you checked the pump is working ? if it's ok; then check the plastic water tubing at the joints starting nearest the reservoir for a blockage and move towards the jets. A lot of times calcium etc will block the jets if tap water was used, so next try cleaning the jets.
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1198 ![]() ![]() ![]() |
+1 with Laurie on fuses, pipes and jets.
stuartj9 Member Since: 18 Apr 2019 Location: Liverpool Posts: 86 ![]() ![]() ![]() |
Thanks - I'd seen the how to guides but wasn't aware there was a manual to download, so thanks!
I wonder if this may help. Found on a webby search for L322 2006 fuse layout.
