Home > Maintenance & Mods (L322) > Leak!! Help, what is it?
stuartj9
United Kingdom 2006 Range Rover Vogue TDV8 Java Black
I've attached 2 pictures. It's right in the centre of the car. There's no warning etc on the dash. Does anyone know what it is and if it's an easy fix or is it a garage job Sad
There doesn't seem to be anything on the path so it's either a really slow leak or, I'm hoping it's the aircon dripping. I think I might be clutching at straws though.
This shows where it is wet.
This one shows above the wet bar. Is the bit above, shown in the pic supposed to be this colour? It looks worse on the pic that without a camera/flash
Pics uploaded correct way and for some reason, this has flipped them upside down Sad
Post #515013 11th May 2019 9:12pm
Clean up dry the wet area
Turn the air con off and take it for a spin.
Return and switch off, leave for five minutes, check underneath
If no leak then air con
Repeat with air con on
If leak then it is the air con .
Post #515028 11th May 2019 11:10pm
stuartj9
Common sense! Cheers Joe. What is the black thing above the wet bar? I was dreading reading the reply, thinking it was going to be terrible news.
Post #515032 11th May 2019 11:28pm
Gearbox/Transfer Box .
Post #515057 12th May 2019 9:41am
stuartj9
Oh no! I'm hoping it's the aircon!
Post #515066 12th May 2019 11:13am
unsolicited
United Kingdom 2017 Range Rover 5.0 SC V8 Mariana Black
If it turns out to be oil, it will probably be this ...
https://www.fullfatrr.com/forum/topic43003...nic+sleeve
Not the end of the world...
Post #515535 16th May 2019 5:53pm
