Home > Technical (L322) > Alternator Replacement 2009 3.6 V8 Range Rover
Mikem
United Kingdom 2010 Range Rover Vogue TDV8 Atacama Sand
After some advice had new battery in January this year all been fine all of a sudden flat battery at the weekend so had the breakdown service out they did a test and the alternator is not hitting the required output required but pick up the engine revs gets to about 13.7 on the output to the battery, the battery is charging ok no battery light coming on .Had a quote for a replacement alternator £600 all in is this a common failure
Post #513609 29th Apr 2019 9:31pm
DIY ?
https://www.fullfatrr.com/forum/topic23089-30.html
and £170 for the part....
https://www.island-4x4.co.uk/alternator-td...30550.html .
Post #513620 29th Apr 2019 11:33pm
Grofus
Ireland 2007 Range Rover Vogue TDV8 Zermatt Silver
Common enough failure at that age. Its the rectifier that goes so see if you can get it repaired rather than a whole new part.
Did mine last month for €80 2007 Vogue TDV8 in Zermatt Silver with Charcoal
Post #513729 30th Apr 2019 4:59pm
Mikem
Thanks for the replies really appreciate the advice, ideally need a garage to carry out the work as back problem has finished my days of spanner work
Post #513751 30th Apr 2019 7:22pm
Mikem
Had the new alternator fitted at my local garage picked it up Friday went to use it yesterday started it up and its leaking coolant badly it looks like it’s spraying from the rad and then onto the fan , would this have been damaged during the work as it was definitely not leaking beforehand
Post #515076 12th May 2019 1:03pm
Yes Evil or Very Mad
Workshop Manual advises removal of radiator to do the job (although it "can" be done without) .
Post #515103 12th May 2019 6:04pm
Mikem
Thanks for the reply, that’s I what thought will giving it back to them tomorrow Sad
Post #515108 12th May 2019 6:57pm
Grofus
Definitely down to them. A piece of cardboard can be used to protect the radiator instead removing it.
Clearly they did neither. Good luck sorting it. 2007 Vogue TDV8 in Zermatt Silver with Charcoal
Post #515112 12th May 2019 7:09pm
