![]() | Home > Technical (L322) > Reversing sensors on when towing |
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2947 ![]() ![]() ![]() |
So I’ve just hooked up the tintent to get it cleaned after the winter.
It’s a factory fitted Westfalia though. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
Robert Member Since: 25 Oct 2011 Location: Perigueux Posts: 2291 ![]() ![]() ![]() |
Maybe to simple, but I am, if the plug is not really pushed in or if the cable of the trailer has a problem the sensors keep on beeping. Does it show the little trailer on the dash when plugged in? |
Balloonengineer Member Since: 03 Sep 2017 Location: Kent Posts: 180 ![]() ![]() ![]() |
The air suspension should also be disabled (orange light on switch) when a trailer is sensed as plugged in
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2715 ![]() ![]() |
The air suspension on MY07 onwards (Terrain Response is fitted) is not disabled when a trailer is detected although automatic selection of off-road height is disabled if rock-crawl is selected. |
No my air suspension is not disabled when a trailer is plugged in. |
