![]() | Home > Maintenance & Mods (L322) > How much rust is acceptable? |
Pawl Member Since: 08 Nov 2017 Location: West Midlands Posts: 712 ![]() ![]() ![]() |
Walk away. There must be better SCs than that!
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3982 ![]() ![]() ![]() |
Wouldn't touch it with a barge pole. It will be impossible to eradicate fully and whatever is done as a repair to the Cills will come back to haunt you after a couple of winters.
ur20v Member Since: 19 Feb 2019 Location: None Posts: 634 ![]() ![]() |
Looks superficial and normal for UK, salt Kaiden roads there.. my Spanish FF has never been off road or seen salt so is like new underneath 😎 |
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2246 ![]() ![]() ![]() |
I see you have an 04 are your sills in a better state? Cheers Current stable: 2006 BMW M6 2007 4.2 V8 S/C FF Gone: 2002 4.4 V8 FF |
Had the car for 8 years but regularly treat it to a coating of oil and grease so to date no corrosion to cills or rear arches or for that matter anywhere else. |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1424 ![]() ![]() ![]() |
My 2004 was waxoyled when bought new and its underside was pretty good when it was sold in 2013. My 2012 by contrast needed a new upper tailgate and had wheel arch rust after 2 1/2 years. It had not been waxoyled as it was a used demo when I got it so not the same opportunity. But in general the later cars seem worse for corrosion, perhaps due to a combination of different paint regulations, higher scrap content in the steel and maybe some cost saving at JLR under Ford. The need to repaint the 2012 322's arches every year from year 3 onwards was a major contributor to my move to a 405.
so CS, do the 405 not suffer rust the same then?
The 405 ought to be better given the aluminium architecture, the wheel arches and tailgate will be aluminium rather than steel. AFAIK the big issue with 322s is the structural nature of the hindquarters, making them costly to replace, and quite a big job too. "Lesser" components such as the tailgate are a costly nuisance too of course but not perhaps as fatal. There will be some steel components underneath the 405, it's too early for me to have a view on durability compared with the 322.
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2286 ![]() ![]() ![]() |
Have to say mine is on 180k and 10yrs and nowhere near as bad as that the cills are relatively rust free |
Wow that’s some big miles on an s/c - good to know they do exist if I keep looking Current stable:
Had this one for coming up to 5 yrs and put over 120 on it they wear out so bits have to be replaced that's all |
You had any engine/sc/gearbox issues? Current stable:
Had a new gearbox on 100k due to a sticking solenoid why they replaced the whole gearbox god knows since then not a problem change gearbox oil every 30k and engine at 10k and diffs every year all good |
Good to know! Cheers! Current stable:
