Home > Technical (L322) > Battery Disconnect/Towbar Electrics. |
Brian Considine Member Since: 15 Apr 2019 Location: Garlinge Posts: 428 |
Sorted - followed the above & apart from a couple of warnings which cleared after a short drive all seems to be in order.
14th May 2019 3:07pm |
MPx Member Since: 29 Jul 2011 Location: South Somerset Posts: 527 |
I've no real knowledge of this stuff Brian, but for reassurance its always worth checking in the Wiki (in the picture space at the top of the page). eg https://www.fullfatrr.com/forum/post67804.html#67804 Mike - MPx
14th May 2019 5:56pm |
Thanks for the info' - I did find that via Google but I just wanted to double check as the towbar electrics instructions just said to "disconnect the battery" with no reference to allowing systems to shut down.
14th May 2019 9:41pm |
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 775 |
Load resistors will stop the fast flashing but won't stop the lights flashing as the ECU fires out its 2v bulb test pulse. You might not want your brake lights flashing randomly. I believe there is an aftermarket interface to cure this, you can stop it with relays. The testing might be stopped with diagnostics. I put it down as too hard and change the lamps to old school. 2007 TDV8 VSE
15th May 2019 7:52am |
I very much doubt if the LED's will react at all to 2v - IIRC the units are rated at 9 > 36volts.
15th May 2019 9:56am |
The issue is the led`s will light up with a small voltage where the normal bulbs won't. The test system fires out 2v which will illuminate the bulb being tested and cause a flash. 2007 TDV8 VSE
15th May 2019 10:09am |
