Home > In Car Electronics (L322) > 2007 (not BMW) android head unit replacement.
Deicist
Hi all,
Been doing a lot of reading about these as I'm about to pull the trigger on purchasing a 2007 TDV8. I know the infotainment system on these is a) integrated into the car quite heavily b) uses the MOST fibre bus and c) is a pain to mess with. However, would the following work:
    Get one of these to provide an Aux input (not sure if this year has Aux in by default or not?): https://www.lrparts.net/vplme0004-range-ro...-2009.html
    Remove the CD changer unit from the glovebox and stick the stock head unit in there instead so I don't lose access to its functions completely (is there space in the 2007 onwards glove box to fit the head unit in?)
    Put an android head unit in, connected to the Aux in for audio.
Any issues with that?
Post #515389 15th May 2019 10:33am
seems to..here are the fitting instructions,
https://topix.landrover.jlrext.com/topix/service/document/114049
and a few threads here on the forum,
https://www.fullfatrr.com/forum/search.php...rch_time=0
Post #515391 15th May 2019 10:39am
Deicist
Thanks Stan. Most of those threads seem to be leaving the stock head unit where it is and using the cable to provide additional functionality via a phone. I want to remove / relocate the stock head unit completely..... so my quesitons are more around whether the stock head unit can be relocated into the glove box? I've seen it done on a <=2006MY but I think there's more glove box space in those.
Post #515393 15th May 2019 11:00am
cant remember anyone doing it here...maybe the cables dont reach? and there would be a fair bit of fettling i should imagine...
Post #515395 15th May 2019 11:08am
Deicist
I'm an unmitigated fettler so not a problem there, I'll give it a go Smile
haven't even picked the car up yet and already pulling it to pieces in my mind Very Happy
Post #515396 15th May 2019 11:09am
Danwilderspin
Any update on this? Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #518100 11th Jun 2019 10:09pm
Deicist
Nah, I've decided to 3d print a tablet mount that wraps around the factory head unit instead. Picked up a nexus 9 for £40, much cheaper than a decent android head unit.
Post #518107 11th Jun 2019 10:35pm
Danwilderspin
Can you post a pic sounds good Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #519047 19th Jun 2019 10:21pm
Deicist
It's still in the planning stages, I'm now working on a raspberry pi based system running 'crankshaft-ng', which allows you to run Android auto on it. Just need to work out where to get power etc from.
Post #519206 21st Jun 2019 10:49am
Deicist
First version of my 3D printed tablet mount here:
https://www.thingiverse.com/thing:3774622
Works really well, now working on an insert for the cubby box so I can stick my phone in there.
Post #523024 27th Jul 2019 10:08pm
Deicist
Well it took a while, but I finally got round to doing it ...
Post #543620 11th Feb 2020 12:14am
Ahah... Saw this on facebook today sir Thumbs Up
Post #543622 11th Feb 2020 12:18am
vnitos
South Africa 2016 Range Rover SVAutobiography 5.0 SC V8 Baltic Blue
Looks great.
Does it retain all the functions of the original LR system, e.g. 4x4 screen, etc?
It seems it took a while, but since you now know what and how to do it - how long will it take you to make another 1 or 2 or so and most important how much will it cost? Mr. Green
Post #543628 11th Feb 2020 6:06am
Deicist
It took a while more because life got in the way than actually being difficult to do Very Happy
I used a BMW E39 adaptor bracket (the plastic surround) because I already had a generic double din head unit and didn't fancy forking out for another one.
However, I've seen on aliexpress you can get a head unit that a) fits an E39 and importantly b) is shallow depth. So it *should* fit straight in. (https://www.aliexpress.com/item/4000320846082.html)
The general process is:
Remove old head unit (this is the bit that takes time, you have to remove the lower glovebox, so you can get at the screws holding the upper glovebox, so you can get at the bolts that hold the passenger airbag to the upper dashboard, so you can remove the upper dashboard....)
The wiring loom for the stock head unit also has one cable that goes to the speaker on the upper dashboard, so you need to split that cable loom as far up as you can, to give you enough slack to....
push the cables through into the space where the lower glovebox goes. At this point I also cut a hole in the top right of the glovebox, to feed the cables through and give me more slack.
Tap into the stock head unit connector for your permanent 12v and ground. I couldn't find a switched 12v on that connector (there's one that comes on briefly when the car powers up, then goes off again after 5 seconds) but handily, there's the interior fusebox right there, and plenty of those fuses are switched.
Put your new head unit in place.
Put it all back together (note: the lower glovebox is a right pig to get back on. the top lines up fine, then you go to put the 2 screws in the inside and they look way out. Persevere at this point, they will go in with a bit of wiggling about and brute force)
Plug the stock head unit back in its new home.
There's 3 coloured wires that look like aerials on the back of the stock unit, I could only get one of them to reach. I suspect the other 2 have something to do with either the navigation, the venture cam or the rear camera..... but I don't use any of those so I'm not arsed. I suspect if you do a bit more investigation you can probably get enough slack on those other 2 cables to get them in there, but I didn't have the time / inclination to do so.
Incidently, if anyone has access to a pinout / wiring schematic for the denso touchscreen I would be immeasurably grateful. I could do with picking up a reverse signal from somewhere so I can wire my reverse camera into the new head unit Smile
Post #543641 11th Feb 2020 11:11am
Danwilderspin
So have you done what I’ve done and just got a new headunit or did you go tablet? Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #543661 11th Feb 2020 5:28pm
