[SOLD] 2002-2005 L322 Nudge Bar VUB000840 | |
SOLD
Nudge Bar (VUB000840) To fit the 2002-2005 Range Rover L322.
It comes as pictured, without any fixtures or fittings.
I will give the buyer a copy of the fitting instructions.
The bits you need to fit this to your car are:
4 x Metal Sleeves, 13mm OD, 10mm ID, 85mm Long.
4 x 8.8 Grade M8 100mm Bolts.
4 x M8 Washers.
This is for your information and are not included.
These are now extremely hard to get hold of.
There are 2 small splits in places you won't see once it is fitted. I have repaired one which you can see in the picture has a slight over spill of gorilla glue, This will be tidied up before it goes. Also the white marks should be removable with something like de-solv-it sticky stuff remover, but would be covered up by your number plate plinth and number plate.
The covers that normally have the parking sensors in and cover the mounting bolts could be replicated with black plastic or similar material.
Cash on collection is preferred.
Postage is to mainland UK only, and excludes the Highlands, Channel Islands, Northern Island and Republic of Ireland.
Payment will need to be upfront by PayPal is you require it to be posted/delivered.
£150
 | Click image to enlarge |
