Home > Technical (L322) > Key won't turn in ignition
Page 1 of 3 123>
Blitz
Australia 2008 Range Rover Vogue SE TDV8 Stornoway Grey
My husband used to post on this forum until he passed away from cancer in 2017. I wanted to keep his Range Rover for sentimental reasons as we bought it when in the UK and imported her over. Needless to say, I'm totally lost without his mechanic skills and could really use some help.
My son took the Rangie to get some new tyres fitted yesterday. They couldn't get the wheel nuts off and ended up cutting one off (so it is now missing one wheel nut). Anyway, to cut a very long story short, it took them so long to get the tyres changed, they apparently left it on the hoist for 4 hours with the ignition on.
When my son finally went to drive home, the key wouldn't turn. After much googling, the bloke at the type dealership disconnected the battery, then reconnected it, and away she went. However, after a 2 hour drive home (we live in remote bush), she wouldn't start without having to disconnect the battery then reconnect it.
I connected the IID tool this morning. Battery with no ignition read 12.2v. After disconnecting the battery and getting her started, it went up to 14.5 whilst running. Upon switching off, it immediately went down to 13.2. There were no fault codes.
The battery is 3 years old. Am wondering if it could be the battery's been stuffed (in which case, would the voltage go up to 14.5 whilst running?) or if it is co-incidentally something else that's caused the problem.
Sorry about the epic post, but I thought more info would be more helpful. I'd really appreciate any direction anyone could give.
In case anyone may remember my husband's posts, his username was Ziggy from memory.
Thanks in advance.
Post #515674 18th May 2019 5:21am
finchi
United Kingdom 2017 Range Rover Autobiography 5.0 SC V8 Carpathian Grey
Does the steering lock disengage when you insert the key? If not, you may have the steering interlock issue as in the wiki entry
https://www.fullfatrr.com/forum/topic40178.html
I had the same fault on my 2007 MY.
Post #515677 18th May 2019 8:00am
dingg1
If the car was ok before thebattery drain down it could be just needing a decent charge up to get back to normal.
Try that first and see how it performs.
If that doesnt sort it there are many threads on this issue and my case was sorted by drilling a small hole in the steering column and applying silicone lubricant its been fine for 3 years now.
Good luck
Post #515691 18th May 2019 9:57am
Blitz
Thanks finchi.
Crikey, that post looked pretty full-on for the likes of me! I hope to the Almighty it's not the steering column. From what I have gathered, they are really, really expensive.
The steering lock isn't engaged at all. Not quite sure if that's good news or bad. Hopefully it's good, hahahaha.
Post #515692 18th May 2019 10:06am
Blitz
Good luck
It was fine before the tyre change episode. I was thinking it's either something to do with battery drain, or just a really weird coincidence.
No wonder my husband didn't trust anyone to touch his baby!
Post #515693 18th May 2019 10:07am
Blitz
I forgot to ask ... would 2 hours driving be enough to get the battery up to scratch? What about the 12.2v? Is that pretty standard?
Post #515694 18th May 2019 10:08am
12.2V indicates the battery is very low on charge, should be a minimum of 12.5-12.6V or even more after a run.
If you have a battery charger available I would be inclined to put your battery on charge at least overnight and if possible longer.
Your problem could just be low battery charge level which charging should resolve. Thumbs Up
Post #515695 18th May 2019 10:27am
Blitz
I like the sound of that.
I don't actually have a battery charger but it would be a good thing to have so I'll get my son to buy one. Makes sense to see if that cures the problem before panicking.
Thanks enormously!
Post #515697 18th May 2019 10:39am
CS
When my 2004 322 had a flat battery the key would not turn, if I remember right the idea was that the car "thought" the battery had been disconnected and shut its systems down to protect itself. In that case charge was supplied from another vehicle via jump leads and a 'system reset' was required, ideally via a diagnostic tool, but in my case done by removing the leads from the battery and shorting them together (off the battery), called a 'hard reset' on here I think. You might want to search or get confirmation from a more knowledgeable person before attempting.
Incidentally some batteries can't stand being discharged to a significant extent, so even if charged up again won't hold charge properly. I have been told the battery needs to be fully charged before it can be tested, if that is your problem you'd need a new battery.
Good luck. Only Range Rovers since 1988
Post #515704 18th May 2019 11:34am
Grofus
Ireland 2007 Range Rover Vogue TDV8 Zermatt Silver
12.5v at rest is about 50% charge. It should be enough to allow the key to turn and start the car but ithe battery is on its way out.
See if an overnight charge gets the voltage nearer to 13v where it should be. A new battery is around 13.2v.
If it wont hold more than 12.5v it would be best to replace it. Good luck. 2007 Vogue TDV8 in Zermatt Silver with Charcoal
Post #515706 18th May 2019 11:47am
stu1
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Java Black
Just looking at the sequence of events here - the car was fine, then the battery flattened. Draining a lead acid battery too low can spell death for it.
I'd get the battery tested, and if there's any doubt, get it replaced as per Grofus.
Post #515707 18th May 2019 12:10pm
Blitz
Good luck.
I connected the IID tool in the hope it would throw some light on the problem but unfortunately, it didn't show any fault codes. Was hoping it would bring up a fault that could be cleared, but no such luck.
Thanks for the tip regarding the battery possibly not holding the charge. I looked up in my husband's folder to see when he got the new battery and being around 3 years ago, it wouldn't surprise me if it's had the dick. How long do batteries generally last? I remember someone saying about 2 years, though in my experience with Land Rovers, they usually last way longer.
Post #515724 18th May 2019 3:53pm
Blitz
Yeah, that's what worried me - that 12.2v should be enough to start her. As the battery is towards the end of its used by date so to speak, I'm hoping that's the problem. I'll get a charger and see if it resurrects, but as you say, probably time to replace it anyway. Here's hoping it's an easy and cheap fix (relatively given the cost of a decent battery compared to a new steering column).
Post #515725 18th May 2019 3:59pm
Blitz
Exactly my hopeful thoughts. Makes sense given the chain of events.
Having said that, I was worried because my son's Range Rover Sport's battery went flat after he spent 4 hours cleaning it (yep ... ) leaving the stereo on the whole time. Once she was jumped, had no problems since. He'd had the Sport for about a year before this happened and have no idea how old the battery was when he purchased her. Not sure if it's the same set up as the Vogue though. May simply not be configured the same way.
Post #515726 18th May 2019 4:05pm
Blitz
A massive thank you to all who replied and contributed to my post.
This morning the battery is reading 12.0v, a drop from yesterday. Am going to investigate getting a new battery fitted so will keep you all posted as to whether that solves the problem.
Thanks again.
Post #515782 19th May 2019 3:03am
Page 1 of 3 123>
