![]() | Home > Technical (L322) > Aux Coolant pump & Control valves |
| knares Member Since: 22 Jun 2017 Location: Perth WA Posts: 836
a photo would be nice as i am not familiar with what you are talking about RR 2005 4.4 petrol
| Highroller Member Since: 18 Jul 2016 Location: Hampshire Posts: 570
Manged to find one on line. It sits on the LHD side of the engine bay.
WOW
| Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 1057
I replaced mine recently due to max heat drivers side its a bit fiddly but an easy swop out. Just remove the control valves you lose a bit of coolant no biggy just refill with a bottle down the hose you removed from the valve then fit the new one. |
Gsxr1250Dave, Did you manage to remove the valves without the bracket. I was intending to clamp the hose to minimize the coolant.
The mounting bracket for the control valves just lift out i also replaced the pump shortly after its only x1 bolt dont bother trying to get clamps in there just lift it all up the hoses are long enuf and flex ok coolant loss is minimal and like i said poor coolant down the hose just before you reconnect it |
I'll give it a go |
As I've never had really good heating, I thought I would investigate. Changed the control valves & auxiliary pump, but no great improvement.
Have you adjusted the little wheel in the centre air vent ??? |
Mine is toasty both sides and i mean toasty then when i need it to be its ice cold. My pump was duff and it was still hot did you fit a new pump or 2nd hand because the 1st pump i tried was 2nd hand and didnt work so fitted a new one and all dorted |
Yep, I've even had the vent surround out to make sure that the bowden cable was still in one piece.
| Ian928 Member Since: 16 Aug 2016 Location: Kristiansund Posts: 85
Do you have park heater? I found the seals in my changeover valve had swollen to the point that both paths were blocked. 2006 Supercharged |
Gsxr1250dave, This is the issue, it's all new?.
You be able to feel the pump running i would start there maybe try flushing the heater matrix out its easy to get to if you remove the phlenum chamber fron the back of the engine |
| All times are GMT |
