Home > Maintenance & Mods (L322) > Deployable Side Steps |
haaris Member Since: 02 Apr 2010 Location: Ballina Posts: 33 |
Hello all - any suggestions if it’s worth putting in deployable aside steps? Family and parents sliding out of seats!
18th May 2019 9:18am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34925 |
i think they are attractive and practical addition to the FF.
18th May 2019 10:44am |
Thank you... I had seen the great deal on Duckworths but then saw it had ended. I’ll PM Dan. Thanks |
18th May 2019 11:09am |
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2926 |
If Dan can’t assist they are £389 on eBay from another dealer 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
21st May 2019 8:21am |
Problem is they are suggesting that vehicles with a body kit require another trim (LR018383 and LR018384)- I’m
21st May 2019 8:35am |
Bushy30 Member Since: 03 Jun 2018 Location: Oxfordshire Posts: 1097 |
Can you post some photographs of what you have? Current: 2011 FFRR Vogue SE 4.4 TDV8
21st May 2019 10:39am |
21st May 2019 11:06am |
Front and back won't be an issue -- the sides will be
21st May 2019 11:19am |
Thanks. Therein lies my problem. Here we don’t know if that side skirting requires removal in order to fit the steps as there is a requirement to use the LR018383 and LR018384 if a body kit is fitted.
21st May 2019 11:24am |
Scottyav Member Since: 11 Feb 2013 Location: Cannock Staffordshire Posts: 1194 |
21st May 2019 12:17pm |
So basically remove the kit I have. Buy the modified sills, and use them as a replacement.
21st May 2019 12:20pm |
I think that was the point I was making -- deployables won't fit with those side skirts -- so can you take them off and see what you have left after they are removed -- it may be the it all looks fine and you can simply remove and fit deployables -- I suspect that you'll need the standard parts, which will be the part numbers you mention.
21st May 2019 12:24pm |
For me if you've got the design kit and no side skirts with steps on they look odd to me and the steps look floating and the valances makes it look complete. _____________________________________________________
21st May 2019 12:36pm |
Oh that's a beautiful machine!
