![]() | Home > In Car Electronics (L322) > Bm54 amp outputs / amp inputs |
| mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 8002
The DSP isn’t an amp, it’s only a sound processor with crossovers inside etc to feed the speakers directly. I do seem to remember that the BM54 amp can do various functions but I’m no expert.
| Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2305
Cheers for the quick response - it’s the non dsp amp I have so it’s not ibus dependant so that’s not an issue. Do you think that this would be the same as the dsp though just an active crossover as opposed to an amplifier? Cheers Current stable:
I recon you will still need an ibus signal to get it to power on. I might be wrong, but I don’t think I am.....if you get me....
I know you don’t need ibus as that’s what I am have been running for a while with a different setup and it’s working ok now just quiet so think a repin to high level outputs to inputs is my next plan! Current stable:
You prob know more about that bit than me then. I’m sure I read it can switch between modes depending if DSP is there, but can’t remember.
| All times are GMT |
