Home > In Car Electronics (L405) > Rear Dash Cam
broncoupe
Rear Dash Cam
Does anyone have a how to for the installation of a Rear Dash Camera
I have fitted the front unit run a cable through the head lining too the back .
But the tailgate is a mystery to me getting through the grommets etc
thanks
Post #516099 21st May 2019 5:57pm
aljo
United Kingdom 2019 Range Rover Vogue SE 2.0 PHEV Santorini Black
https://www.fullfatrr.com/forum/topic27439.html
its in the wiki Thumbs Up excellent write up and exactly as i have done mine Thumbs Up Thumbs Up
there is a post somewhere that explains the cable fitment through the ruber grommets etc but cant for the life of me find it Big Cry
it may be on rrsport or disco3 Last night I lay in bed looking up at the stars in the sky and I thought to myself, where,s the f**king ceiling!!
Post #516127 21st May 2019 9:11pm
For the L322 it made some sense to mount it to the car roof as you shut the tailgate hard & the camera might fall off.
On the L405 with soft closing, I'd me more inclined to stick it onto the rear screen - but I haven't looked at how you'd do that......
Post #516137 22nd May 2019 5:33am
broncoupe
Thanks for ideas but L405 is completely different
The tailgate is moulded from some sort of Resin
Then painted so the only access is the lower panel to the boot lock etc.
Also when closed there is a hump at the top which fits against factory head lining.
You would need to drill quite a large Visible hole
This is a lease car so its a none starter
Has to go at the base of the rear window I feel
Post #516138 22nd May 2019 5:49am
fin
United Kingdom 2013 Range Rover Autobiography SDV8 Causeway Grey
Due to way it is made the only way you can pull the cable through it to remove the rear spoiler which you can then drill a hole that cannot be seen and fish it through.
I had one fitted to my L322 and when I came to sell it and removed it it pulled the privacy film off with it so I vowed to install this one differently, I’ll add a photo over the weekend I bought an L shape bracket from B&Q and stuck it on the internal C pillar and I personably think it looks a good install and still give good vis ability.
Post #516223 22nd May 2019 8:18pm
fin
Like so. I though it was a good place as the parcel shelf does not lift up all the way like an L322 so will not hit it.
Post #516445 24th May 2019 6:52pm
broncoupe
good solution that
thanks
Post #516469 25th May 2019 6:46am
SCL
England 2015 Range Rover Autobiography SDV8 Causeway Grey
I had mine professionally fitted. They initially fitted it to the top of the rear window. I hated it as I could see the camera and cable in my rear view mirror. They relocated it to the bottom of the window and I now can’t see it.
I am sure they managed to run the cable through the left hand boot strut (as looking from the back of the car) and then down into the plastic panel in the bottom of the boot lid, then up though the plastic to the bottom of the window by making a discrete cut in the plastic. It did take longer to fit doing it this way. Hopefully the photos make more sense. The blurred arc line across the top of the photo showing a car behind me is the heating element. When playing a recording back you can’t see the arc. The black line in the bottom right corner is the power cable to the camera.
 You can't swim uphill in custard all the time, sometimes you just have to go with the flow.
Post #517690 7th Jun 2019 12:00pm
is the DAB and FM radio reception still ok?
Post #517691 7th Jun 2019 12:03pm
SCL
Hi Stan
I usually only play music though my iPhone. I will check it out tomorrow and let you know.
Steve You can't swim uphill in custard all the time, sometimes you just have to go with the flow.
Post #517695 7th Jun 2019 1:40pm
thanks steve..
Post #517697 7th Jun 2019 2:13pm
Chalky
Stan
No problems with reception, I have identical cameras and installation as SCL Thumbs Up All LR cars from 1984
2021.5 Vogue SE D300 Carpathian Grey
2018 Vogue SE British Racing Green GONE
Post #517698 7th Jun 2019 2:19pm
thanks chalky..i was curious cos there's a thread here somewhere where its said that the rear dashcam interferes with radio reception..
Post #517699 7th Jun 2019 2:32pm
broncoupe
Thanks for the pictures will have a go and post results
Post #517701 7th Jun 2019 2:57pm
Macpaul
2019 Range Rover Vogue SE 2.0 PHEV Siberian Silver
You’re right Stan there was.
Several Blackvue dealers admit the shielding on the cabling is not great and I’ve had certainly DAB problems since the (professional) installation.
I’ve got a van with a stick on windscreen aerial that gets a lot better DAB performance in the same location.
I’ve tried ferrite collars to no effect.
In my case it’s just a trade off - dash cam v DAB.
Post #517726 7th Jun 2019 7:07pm
