Home > General (L405) > Finding the spec of your car
Gazm007
United Kingdom 2013 Range Rover Autobiography SDV8 Havana
Hi There
Was wondering if someone can help. I'm about to purchase a L405 AB and wanted to know if there was somewhere on the web i could find the original spec of the car.
any help appreciated
Thanks
Gareth
Post #516300 23rd May 2019 11:43am
adara
Romania 2019 Range Rover Vogue 2.0 PHEV Santorini Black
https://topix.landrover.jlrext.com/topix/vehicle/lookupForm
register
Independent Operator Login
login with previous credentials
input VIN
view all vehicle details
Post #516303 23rd May 2019 11:55am
Bushy30
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
Hi Gareth,
Do you know the VIN number? if so create an account (free) on Topix -- you'll then be able to enter the VIN and find all the things fitted (and not fitted) to the car.
Bushy Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
2004 FFRR Vogue 4.4 V8 with LPG
1997 P38 4.0 SE with LPG
1997 P38 4.6 Vogue with LPG
Post #516304 23rd May 2019 11:55am
Gazm007
thanks for your help chaps. I can already see i'll be spending a lot of time on this forum!
so i managed to log in.
i'm guessing it list every extra and any the car does not have are listed as LESS
here are the ones mine came back with
LESS ENGINE BLOCK HEATER
LESS INCONTROL APPS
LESS INTERIOR BADGE
LESS KIT-TIRE REPAIR SERVICE
LESS LOADSPACE STOWAGE RAILS
LESS REAR COOL BOX
LESS SMOKERS PACK
LESS SPECIAL VALUE PACKAGES
can anyone enlighten me as to what the following are
LESS INCONTROL APPS
and can i assume it has all the other extras offered for the car.
Post #516306 23rd May 2019 12:08pm
Bushy30
Yes Sir, and No Sir -- Sad
Less means you don't have it -- so engine block heater will also be known as Fuel Burning Heater (FBH) which can be time controlled or remote controlled -- lots of threads on here about what that is and does.
IncontrollApp is the funky things you can do with a Mobile app I believe. Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
Post #516307 23rd May 2019 12:17pm
forever
Dont think that the FBH, thats listed as
PARK HEATING W/REMOTE CONTROL and FUEL OPERATED HEATER
Post #516319 23rd May 2019 2:41pm
Andy B
Mine has :-
Fuel Operated Heater
No Park Heating
LESS Engine Block Heater
So the Fuel Operated Heater is on a 7 day timer and can be programmed to heat the cabin. The control is from the main screen, but I had to turn mine on using an IID tool as it was disabled when I purchased the car. Works great now....although don't need it this time of year Smile SDV8 AB MY 2019
SDV8 VSE MY 2015 - Gone
5.0 S/C AB MY 2010 - Gone
4.2 S/C VSE MY 2006 - Gone
Post #516321 23rd May 2019 2:57pm
Bushy30
Aha -- OK so it seems ignore my FBH comment about the heater Wink Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
Post #516322 23rd May 2019 3:02pm
Andy B
It's confusing Sad SDV8 AB MY 2019
Post #516323 23rd May 2019 3:17pm
Gazm007
it certainly is confusing as one of the fobs has the extra remote for the heater but the dealer selling the car said he did not know how it works. I guess i'll play around with it when i get the car (although not exactly the weather to be testing the remote heater!)
Post #516351 23rd May 2019 6:33pm
roberlar
United Kingdom 2013 Range Rover Autobiography SDV8 Santorini Black
I have the same MY AB and from what I understand the FBH can be used in hot weather to cool the car as well. It doesn't operate the air con but draws in cooler air from outside the vehicle. One thing I've noticed is the remote has a very long range and several times wandering around home with keys in my pocket it's switched itself on through unintentional button contact.
It's a fantastic device during winter, but I can't see a massive benefit in summer so I've taken the remote off my fob until next winter as it does draw a fair amount of current and then the annoying 'battery low please start car' message appears.
Post #516356 23rd May 2019 7:24pm
Engine block heaters are for extremely cold environments & wouldn't be fitted to any UK car.
They are electric & plug in when the car is parked, much like electric cars. In said cold environments, all parking spaces have plug in facilities.
I first saw them many years ago in northern Finland - inside the arctic circle
Post #516360 23rd May 2019 8:16pm
Fleagle_UK
United Kingdom 2014 Range Rover Autobiography SDV8 Luxor
If yours is a AB then it will have remote heating (fbh)/ ventilation as standard. The remote simply switches it on or off for 20 mins or so depending on your car battery charge level and if the BMS is in a good mood that day. Smile The HEVAC ecu decides if the car should be cooled or heated based on ambient air temp. If approx <15’C then it heats (major browny points from wifey in winter! Laughing ). If 15’c or above it ventilates the car (note it is not air conditioning!)
As Alistair said. Dont fret about the block heater. That is for mega cold places that laugh at us when the country comes to a stand still coz half a centimeter of snow has fallen on london. Laughing
Post #516362 23rd May 2019 9:40pm
DrF
United Kingdom 2013 Range Rover SVAutobiography 5.0 SC V8 Orkney Grey
Thumbs Up Thumbs Up
Post #516372 23rd May 2019 11:14pm
Felstmiester
England 2015 Range Rover Vogue TDV6 Santorini Black
So the L405 does come with a fbh?? I’ve got what looks like a Fbh under the bonnet but no mention on the spec. But it does say it has a ptc heater. The latter surely replaces the need for a fbh no?
Post #516415 24th May 2019 2:14pm
