![]() | Home > Maintenance & Mods (L322) > That did not go well! |
WB Member Since: 26 May 2016 Location: London Posts: 303 ![]() ![]() ![]() |
Sorry to hear about your experience! A recommendation I read which helped me change over my wheels was to keep a door open which stops the suspension from going up or down. Otherwise the vehicle tries to level itself even with the engine off.
Bradders Member Since: 03 Dec 2018 Location: Gods own country Posts: 417 ![]() ![]() ![]() |
I got a puncture and changed a wheel a couple of weeks ago on the road outside my house. I used my 2 tonne trolley jack and jacked under the rear suspension arm and then put an axle stand under the jacking point. 2 tonnes is plenty to jack one corner so it may be your trusty old Draper is knackered. It is a bit scary how high you need to lift the car even with a door open to stop it levelling out. Current: FF Westminster money pit
Tugger Member Since: 28 Feb 2019 Location: Scotland Posts: 247 ![]() ![]() ![]() |
Cheers both, I'll try it with the door open next time, and see if I can find a more solid surface. My street is a bit of a hill so that's not really an option. Maybe see if I can find a big solid piece of wood in the back of the garage somewhere, that might help.
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4341 ![]() ![]() ![]() |
Land Rover Discovery red bottle jack under suspension. 2 pumps. Wheel off ground. Job done.
philip1972 Member Since: 16 Jun 2017 Location: Marval 87440 Posts: 527 ![]() ![]() ![]() |
My 2 ton Draper buckled under 1 corner of my Disco.
Do you have a link for this? Looking on ebay, there are loads of different kinds, not sure which is the correct type 09 RR Westminster 3.6TDV8 - Stornoway Grey / Black interior - now gone (sad face) Nissan X Trail 1.6TDCi Tekna Fiat 500 1.2 |
kds2 Member Since: 30 Sep 2017 Location: lincoln Posts: 225 ![]() ![]() ![]() |
I just leave the door on the first catch and key out, not gone down yet. |
https://www.ebay.co.uk/itm/For-BMW-1-2-4-5...2749.l2649 This is the one I bought - decent quality and hasn't deformed after many uses. it looks tiny when it arrives and initially I thought it was the wrong size but it is the correct one. |
👍 09 RR Westminster 3.6TDV8 - Stornoway Grey / Black interior - now gone (sad face)
Update: SGS jack arrived a day early so did the job today. What a difference with the 3-ton jack, lifted the car easily.
Looking good - nice job. |
Gyre8 Member Since: 14 May 2017 Location: Wolverhampton Posts: 259 ![]() ![]() ![]() |
@ Tugger.
I didn't but it was in the back of my mind to do it. I've not driven the car at speed yet but if I feel any wobbling I'll be getting them balanced. I'll be going to work tomorrow so a bit of a motorway blast on the cards, will report back after that. 09 RR Westminster 3.6TDV8 - Stornoway Grey / Black interior - now gone (sad face)
jim4244 Member Since: 31 May 2012 Location: UK Posts: 855 ![]() ![]() ![]() |
Those new wheels really set the car up 👍
