Home > Technical (L322) > Steering column fault
rattly
Hi, my TD6 has recently developed a loud clicking noise from dash area when I unlock it, and today the steering wheel adjustment has stopped going up and down (back and forth is fine) and is stuck quite low, would I be right guessing the motor drive has gone? Can still hear a whirring when I operate adjuster! I have a V8 Vogue that I am just about to sell, so could temporarily borrow any bits to try if needed. Also steering has seemed a bit notchy when cold recently, V8 is much smoother! Any advice gratefully received. Thanks in advance.
Post #516680 27th May 2019 4:02pm
MarshallW11
Canada 2003 Range Rover Vogue Td6 Giverny Green
On my TD6, the white plastic attachment that holds the motor in place had snapped. Haven't gotten around to fixing it yet, but if you remove the footwell cover you can get an easy look up in there to see if something jumps out at you.
Post #516687 27th May 2019 5:48pm
rattly
Lovely, will do, thx for the reply mate
Post #516688 27th May 2019 5:57pm
Weegie
Have a look here. Might help https://www.rangerovers.net/repairdetails/steering/tilt3.html John
GAP iiD BT-Sold
Post #516694 27th May 2019 6:51pm
rattly
Thanks, that's excellent mate, will pull it apart tomorrow...
Post #516710 27th May 2019 8:31pm
