Home > Technical (L322) > Oil level sensor questions
DrRob
This morning with a cold engine I was able to check the level without opening bonnet and doing the double cruise control click.
I thought that was not possible?
It wouldn't let me check it after a 30mile run into work after switch off which is right
Whistle Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #516742 28th May 2019 9:52am
Baltic Blue
Both are right.
You can check the oil level before starting the engine, ie cold.
You are not able to check the oil level after running the engine until at least 20 minutes after stopping the engine.
If you want to check level immediately after running engine, you can do so by opening bonnet, getting the “oil level not available “ message, then double clicking the C C cancel button.
The level should then be displayed.
Post #516743 28th May 2019 10:07am
DrRob
So I can check level when cold in morning without bonnet open or double clicking? Is that right?? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #516744 28th May 2019 10:08am
Baltic Blue
Yes, that is the correct method to check the level., ie bonnet closed, but before starting the engine.
Just don’t put your foot on the brake pedal.
Post #516746 28th May 2019 10:20am
GGDR
I thought it had to be warm?
. Cheers, Greg
Post #516753 28th May 2019 11:23am
Baltic Blue
I check mine first thing in the morning whilst car is still in garage because my drive is on an incline and garage is only level area.
I re-check it warm occasionally if I am on a flat car park.
Post #516754 28th May 2019 11:31am
DrRob
Thumbs Up Thumbs Up Thumbs Up Thumbs Up Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #516757 28th May 2019 11:47am
GGDR
Thanks Mike, I never knew I could do that.!
Thumbs Up Thumbs Up
. Cheers, Greg
Post #516761 28th May 2019 12:05pm
nino_nino
DrRob,
when checking oil level on the cold engine, oil level should be in the middle or one notch above. this way when you get engine to the working temperature oil lave will be one or two notches below max and that is correct level. do not overfill.
Nino, Thumbs Up 2012 TDV8 Black Edition
2000 Disco. TD5
1975 series III
Post #516764 28th May 2019 12:39pm
DrRob
Nino
Yep, understand that from the oil change thread Thumbs Up
I never knew you could check from cold Thumbs Up
Rob Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #516784 28th May 2019 4:21pm
