![]() | Home > For Sale & Wanted > 19 inch wheels with Vredestein Wintrac 4 Extreme tyres |
| Japseroony Member Since: 18 Nov 2008 Location: North East Posts: 426
Just a point to note, they wont fit over the 2011 Brembos as these are bigger due to the new engine - sorry. "UNDERSTEER" ----is when you hit the fence with the front of the car.
| rory Member Since: 30 Dec 2009 Location: Berkshire Posts: 41
Thanks - didn't know that. Not sure if they would fit on a 2010 5.0 SC either. So to be safe - will fit over Brembos on either the 3.6 TDV8 or 4.2 SC. Cheers Rory Last edited by rory on 23rd Feb 2011 11:24pm. Edited 1 time in total |
| dan_uk_1984 Member Since: 12 Nov 2008 Location: Bude, Cornwall Posts: 4014
And FYI you can get weights that stick inside the wheel rather than are crimped on the outside. Looks a bit neater. That sounds like an a-hole comment but its not meant to be! |
| Gazellio @ Prestige Cars Member Since: 22 Jan 2010 Location: Chilterns, UK Posts: 11309
Dan, not wanting another argument tonight but it has been explained to me by an expert wheel balancer (That I trust) that the reason those weight lips are there is that to balance a wheel (properly) you need some of the weight on the outside and when all of the weight is hidden inside the balance is never perfect. Thus the reason most LR 19" have a "Weight rim" on the outside (and 20" + style wheels will never be perfectly balanced) |
Why only the 19's and not the 18's or 20's? After all, your balancing the tyre, not the wheel.
Plenty about UFO's and the US not going to the moon on the Interwebs too.....
So LR make cars with wheels that can't be balanced? Not sure I buy that.
Dan,
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35882
a 'static' balance is perfectly acceptable ..static being only balancing the inner rim lip..
| JOKER Member Since: 11 Sep 2008 Location: Sconnie Botland Posts: 15876
There that's you all told .................... |
| All times are GMT |
