![]() | Home > Technical (L322) > Mass Airflow Sensor |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6431 ![]() ![]() |
You have to do the numbers
KRV24 Member Since: 02 May 2016 Location: Berkshire Posts: 35 ![]() ![]() ![]() |
Very fair point on the fact the first one has lasted 9 years.
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3561 ![]() ![]() ![]() |
Is yours a 4.4 or 3.6 ? Cheers, Greg
3.6 mate Range Rover Vogue SE 2010 |
Gotcha.
To be fair I didn’t ask if an original LR part would be used, but given the value of the quote it would certainly indicate non original. Will book it in and get it changed, nothing more unnerving then staring at an engine light |
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2951 ![]() ![]() ![]() |
My 3.6 keeps throwing a fault and going into restricted mode. It was a daily occurance and turning it off and back on again cleared it. I changed the top hoses to silicone even though I couldn't see any faults with the old rubber ones. it was fine for three days and then faulted again. It wasn't every day though so I thought I'd solved it.
Strider Member Since: 08 Jun 2015 Location: Hertfordshire Posts: 508 ![]() ![]() ![]() |
Why not try a MAF aerosol cleaner first?, what have you got to lose. Do a search online, also there are "how-to" vids on you tube. I cleaned the one on my octy' vrs and it did run smoother |
An update on the engine light and restricted performance warning, which doesn’t restrict performance?? Was compelled to do 500 mile round trip to drop a relative off, the performance restriction light came and disappeared numerous times despite cruising at a steady 80+ there and back.
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4349 ![]() ![]() ![]() |
Are you using Rovertune in Reading? They are considered one of the best in the area |
3.6 or 4.4 KRV24 ?
3.6 mate.
Sandy Choda Member Since: 05 Sep 2017 Location: Stafford Posts: 17 ![]() ![]() ![]() |
Hi KRV24,
Hi Sandy,
