Home > Maintenance & Mods (L322) > Yet again suspension
mudknight
2003 Range Rover Vogue Td6 Java Black
Suspension problems yet again , i jacked the car up to check a couple of things , when i let it down and turned it round I noticed the suspension wasn't working, pinging on the dash saying inactive , but there are no red lights at all on the suspension dash . The rear is inflated but front is flat to the floor.
Post #516893 29th May 2019 9:08pm
Check your front height sensors, either broken or reversed, or you exposed a hole in one of your airbags.... .
Post #516909 30th May 2019 12:06am
Fraynizzle
United Kingdom 2005 Range Rover Vogue Td6 Java Black
Reversing the height sensors is easily done after having the car fully jacked up. then the car doesnt kow whats going on a deactivate the suspension.
Post #516924 30th May 2019 10:54am
mudknight
I've now checked the height sensors , they seem correct , I've disconnected the battery for an hour and half to see if things reset but they haven't , obviously fuses and relay checked .
Post #516927 30th May 2019 11:04am
Highroller
United Kingdom 2005 Range Rover Vogue SE 4.4 V8 Java Black
Height sensor wiring issue on that side?. Is the pump working, can you hear any air escaping?.
I've had it when there's been an issue & the suspension lights all go out. Once you trace the issue, they will all come back on.
Post #516930 30th May 2019 11:28am
Gsxr1250dave
Where about are you if your local il come plug my hawkeye in for you
Post #516950 30th May 2019 2:00pm
yelnats69
United Kingdom 2011 Range Rover Vogue 4.4 V8 Zambezi Silver
Did you fix the problems
Post #540018 10th Jan 2020 8:04am
mudknight
Still having problems with the suspension , I'm looking into a cheap fault reader so I can just clear it as that's all they do every time I take it into mechanics
Post #541321 21st Jan 2020 8:27pm
RichM63
France 2006 Range Rover Vogue TDV8 Stornoway Grey
I guess that you have tried the full left lock to right lock engine on dance, whilst whistling The Good Bad and Ugly?
Best Rich
Post #541328 21st Jan 2020 9:28pm
yelnats69
Where are you located I am in Dymchurch Kent will be in Portsmouth this weekend I can plug mine in and read and switch off the code
Post #541331 21st Jan 2020 10:03pm
Danwilderspin
Any money it’s the steering angle sensor at your age and mileage - you can change it fairly easily if you have small to medium hands Current stable:
2015 5.0 V8 S/C AB
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #541351 22nd Jan 2020 12:04am
yelnats69
for just reading and switching off codes, eBay bt reader under £10 and download Torque for free, codes are listed on the net.
no help with the suspension though.
Im trying to find what OBD tool will check and set the suspension
Post #542631 1st Feb 2020 12:40pm
yelnats69
will the sensor show up in fault codes, my problem just throws up the yellow suspension fault now and again
Post #542632 1st Feb 2020 12:44pm
pcourtney
not sure anything cheap will do it, the only one I have seen is £50 quid on ebay and takes 60 seconds to clear EAS faults
https://www.fobfix.com/products/range-rove...&_ss=r
£50 quid on ebay
https://www.ebay.co.uk/itm/Range-Rover-L32...SwclBbczzk
Post #542655 1st Feb 2020 4:11pm
