Home > Technical (L322) > 2011 tdv8 is this normal
GGDR
That's what I thought but then I keep reading EGR's can't be blanked on the 4.4 and so I'm wondering if the ECU somehow compensates?
If the ERG flow is restricted - I'm interested to know would this affect rate of DPF fill?
. Cheers, Greg
Post #516905 29th May 2019 10:01pm
DrRob
We need a "how to decoke your inlet system" step-by-step guide on here Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
I use www.glenrands.co.uk Great independent specialist!
Post #516914 30th May 2019 6:13am
GraemeS
Australia
The throttle will be closed further to ensure that the correct (low) flow through the MAF occurs.
Post #516916 30th May 2019 7:25am
GGDR
So responsiveness and performance would be affected would you say Graeme?
Possibly economy too?
What about soot output (to my question about DPF).
Greg Cheers, Greg
Post #516943 30th May 2019 12:11pm
Baltic Blue
Greg,
Soot levels...
I tend to think that it probably does increase soot levels.
My thinking being..
Mine used to be much lower levels every time I checked live values until about 18 months ago when I started to see much higher levels more often.
So I assume the gradual build up of grime in the inlet track is in part responsible.
Having said that I still find that a good motorway run once a month or so drops the soot level back into low single figures, and I have never had an actual DPF warning, mainly because as soon as I see 17.5g I do a good burn run.
Post #516946 30th May 2019 12:28pm
GGDR
Interesting Mike, I'm still trying to understand the root cause of soot / DPF fill.
I haven't opened up my intake system but will be doing it soon now!!
Keen to hear all thoughts on this.
. Cheers, Greg
Post #516947 30th May 2019 12:42pm
Baltic Blue
Greg,
The only real proof will be if you last longer between Active regens for similar driving conditions.
At the moment it takes me 4 to 6 weeks of stop- start town driving to get from 2.5g to 17.5g , but I tend to do at least 1 decent run a month which extends the gap a bit.
I tend to think 1 good burn per tank full is normal for my usage.
If I find them needed more frequently, then I will bite the bullet and strip it all down for a good clean out.
Post #516951 30th May 2019 1:04pm
GGDR
Yes you're right Mike. I'm reaching 17.5g or even 20g for every tank of fuel. i.e. I'm having to do a regeneration per tank. Some tanks I don't get out of town so I can't get a 'natural' region within my tank cycle.
I accidentally filled with Shell Ultra (or whatever it's called) and out of interest I wondered if I might get longer reaching 17.5g. At the moment I still have some of this tank left but it's looking like the grams are climbing at the same rate. So this I think eliminates premium fuels as a fix/improvement. And since premium fuels just have more additives, I also tend to think this proves additives would not help.
. Cheers, Greg
Post #516952 30th May 2019 1:13pm
Baltic Blue
I have tried putting additives in just after topping up, but found over a 4-5 month trial period they make no noticeable improvement , but I do always use supermarket standard diesel.
I went to Tenerife for four weeks in February, so when I got home I couldn’t wait to get it out of my garage and go for a good run.
I immediately thought wow!! this thing certainly has still got more than enough power for me, so I don’t think the build up of crud affects performance very much, and although I am not fanatical about checking mpg, I do know that every time I fill up I reset the trip and it always shows just over 500 miles range , so mpg has not changed over at least the last 3years of usage.
Post #516954 30th May 2019 1:38pm
GGDR
What's your actual tank range Mike, do you set your trip when you fill up?
. Cheers, Greg
Post #516957 30th May 2019 1:51pm
Baltic Blue
Yes, every time.
I reset it so 500 miles would be tank range, calculated using mpg over previous 3/4 tank usage.
I always brim it and refill when range gets below 100 miles.
I went to North Wales for a weekend away last week and it averaged 32mpg overall over the 250 mile round trip.
Post #516960 30th May 2019 2:00pm
GGDR
500 miles is very good Mike. But I'm not sure the miles remaining is accurate at all.
I go lower than you, brimmed full and run down to 25 miles remaining, orange light on.
Which, when I fill is usually 85-87 litres back in.
On that basis, my range is a bit like this
All city tank: 300
Mixed city and m-way 400
All m-way 500
. Cheers, Greg
Post #516990 30th May 2019 8:33pm
