![]() | Home > Maintenance & Mods (L322) > Rear Tailgate strap rust |
| mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 8002
I don’t think the damper supports anything, just slows it down opening, so you will still need straps, plus there is only a single damper used, just on the right side, when it’s fitted at the factory.
I’m not aware there is an upgrade for the straps? Have I missed something?
| scotcruz Member Since: 03 May 2017 Location: S C O T L A N D Posts: 391
Think they come standard on 2011 MY. The wee strut is on the right side lower tailgate.
| rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1198
Replace the straps, they will fail if rusting. See the various threads on here (Stan got dumped on the deck when his failed).
Cheers Richard, I was wondering if there was any greater benefit of adding the strut other than the booth not banging hard and coming down slowly. Not really keen on drilling holes, especially after some folk report the screws went loose after a short while. Current:
Hi Scot
| Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3888
I have had both, but was always happy with earlier Td6 with no strut.
| Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6434
Retro fitted on two FFRR's - just enjoyed the damped drop of the tailgate. No issues with screws coming loose, I tapped the holes I made so the set screws (bolts) are held nicely in place. Otherwise make smaller holes and use self tapping screws .
| Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3277
Replaced both straps last month. Didn't bother with the damper. Don't really see the need for it. Just lower it by hand. One of the new ones had a nipple on it for the damper.
Cheers folks... looks like I will skip the damper.
| Bushy30 Member Since: 03 Jun 2018 Location: Powys Posts: 1102
https://www.fullfatrr.com/forum/topic48870...ate+straps Current: 2011 FFRR Vogue SE 4.4 TDV8
| andygts Member Since: 16 May 2015 Location: Yorkshire Posts: 367
Mine were seized when I first bought it years ago, when removed the cable was fine and the crimp, it was just the bush that spins that had rusted and from memory theres some plastic mixed in somewhere.
As per Bushy above. 2008 Stornoway Grey 3.6 Tdv8 Vogue - SOLD 2005 TD6 Java Black Vogue - Written off!! GAP iiD BT-Sold |
| Rapiscan Member Since: 28 Apr 2018 Location: North Lincolnshire Posts: 182
DON'T buy the cheaper cables, the covering cracks and splits and cables rust for fun in 5 mins, even though I'd dunked em in grease! I'll be replacing em AGAIN soon before they snap but with original parts! 2008 L322 Vogue 3.6 TDV8 in Java Black with parchment and Navy interior. 125000mls.
| All times are GMT |
