![]() | Home > Technical (L322) > Intermittent Air Conditioning |
paul70 Member Since: 06 Mar 2018 Location: North Yorkshire Posts: 101 ![]() ![]() ![]() |
My Air con has stopped working properly so I took it in to have the gas checked while I waited at a local garage who do air con.
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6419 ![]() ![]() |
Have you whacked the air con onto max with control knobs at 16 degrees, full fan ?
Had it to the max using max air con button which puts full fan on and temp knob as low as it goes but still no joy! |
Hmmm sounds like compressor not kicking in
millerj90 Member Since: 25 Oct 2010 Location: Melksham Posts: 339 ![]() ![]() ![]() |
kooky_guy Member Since: 25 Nov 2011 Location: Sandhurst, Berkshire Posts: 386 ![]() ![]() ![]() |
As millerj90 says, it's probably the valve. The 2010 facelift ones have a different mechanism on the compressor whereby it doesn't have a clutch and runs all the time with the output being controlled by a valve. This valve was a bit iffy and begins to stick. There is an updated part available but the compressor needs to come out to replace it.
Thanks folks that's exactly the kind of info I was after. I think I'd better start looking for a new compressor! |
