![]() | Home > Technical (L322) > 4.4 v8 noisey start when hot |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35753 ![]() ![]() |
sound like the oil isn't getting to the tappets on a hot start , could be low oil pressure from the pump..did this start after the oil service? ... - .- -.
tommac22 Member Since: 10 Nov 2010 Location: devon Posts: 55 ![]() ![]() ![]() |
thanks for the reply scarey- yes my inital thoughts were low pressure but light goes out almost instantly. It may well be worth me checking the pump i guess- anyone any ideas on where its located in the m62? It was doing this prior to the oil change also. |
have a look on RAVE [download on wiki] ... - .- -.
What oil did you put in there on the last oil change? If you took it to a garage they may have put an incorrect grade in, if it was too thin then it tends to drain out of the top end too quickly (when hot) and too thick it doesn't get to the top end quick enough (when cold) so as Goldilocks said: "mmm, correct grade of oil; nom nom nom"
dan,
You need to connect a pressure gauge to determine exactly what the oil pressure is doing. Any good garage should be able to connect one up and take readings.
thanks for comments- will get the local independant on the case! |
Was it doing it prior to the service? Our oil filters can sometimes break up into bits. ![]() |
apparently it was DAN.. ![]() Y. O. L. O. . |
Terribly sorry old chap. I think I must have been replying as other replies came through and I wasn't paying full attention. *Hangs head in shame* ![]() |
