Home > Maintenance & Mods (L322) > To flush or not to flush! That is the question!
Andyschargedse
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Java Black
What’s your opinion on gearbox servicing? Should I get a mega flush done on my 4.2 supercharged or just drop the oil and new filter? I can’t decide which route to go tbh guys
Post #517421 4th Jun 2019 3:08pm
JST
England 2012 Range Rover Westminster 4.4 V8 Stornoway Grey
i will do oil and new filter on mine @ 60ish K same as i did on the last one. my reason being i dont want all the deposits being cleaned off the components in the box and then floating about causing problems later with the new detergents cleaning everything. Cheers
James
Post #517430 4th Jun 2019 4:31pm
Mikey
When flushing, detergents should not be used with the 6/8HP boxes...
Post #517437 4th Jun 2019 6:14pm
DrRob
Had my 8 speed megaflushed by Bodsy a few months back as a precautionary maintenance. All fine. He didnt use any detergents or Dr Tranny just 8 speed oil Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #517444 4th Jun 2019 7:03pm
Andyschargedse
👍🏼 Where is he based please
Post #517452 4th Jun 2019 8:24pm
DrRob
Mobile out of Shropshire.
www.updatesbybodsy.co.uk Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #517465 4th Jun 2019 9:13pm
Andyschargedse
Don’t think he would come all way to me though lol
Post #517470 4th Jun 2019 9:24pm
DrRob
He goes all over. Text him. Mobile on contact us page of his website Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #517473 4th Jun 2019 9:51pm
Mikey
JAS Land Rover is in York, and capable of flushing the 6 and 8 speed boxes Thumbs Up
Post #517479 5th Jun 2019 7:28am
Mikey
This is the best explanation I can find of flushing versus drain/refill Thumbs Up
Quote:
do an experiment, take a 500ml drinks bottle fill it with water and add 10ml of blue food colouring, the water is the good fluid the food dye is the contaminants.
It should be a deep blue now,
Pour half of it away and add 250ml of water.... what colour is the liquid in the bottle?
now do it again,
And again,
And again,
each time you do it, youre changing a percentage.... the first time 50%, the next 75%, 87.5%, 93.75% 96.88%, the official figure for out equipment is 98%.... and we didnt use £1100 worth of fluid to get it....
imagine that’s 7litres of £30 per litre fluid everytime you do it... and the fluid is still dirty and contaminated, and you’ve spent £850 on fluid.....
The flush procedure is as effective as changing half the fluid 5times, all in one go using half the amount of fluid.
(Prices based on an 8 speed ZF, but the basics are the same)
Post #517480 5th Jun 2019 7:32am
Paul thornton
I was always told that the best method was to drop the oil and replace. Do a couple of hundred miles then drop the oil again, remove the sump, replace the filter and refil.
Post #517487 5th Jun 2019 8:51am
Pawl
England 2007 Range Rover Vogue TDV8 Cairns Blue
Just to add my tuppence worth :
If you look at the ZF documentation, they recommend an oil & filter / pan change NOT flushing.
It doesn't necessarily mean they're against flushing, but all of their gearbox durability / life testing will have been based on their recommended method of servicing at their recommended intervals.
Flushing done well, obviously works.
Flushing done badly I'm sure can do harm.
A "standard" auto transmission oil & filter change is hard to mess up, other than incorrect amount of oil put back in, but that should be manageable if you've got the "skills" to get the car in the air safely. Paul,
2001 Discovery 2 TD5, 211,000 miles & climbing
2006 FFRR TDV8 Vogue 151,000 miles & now sold
Member of Midland (Land) Rover Owners Club, www.mroc.co.uk
Post #517490 5th Jun 2019 9:41am
DrRob
As ever, make your own mind up with the evidence presented Thumbs Up
For me, a lot of very experienced LR mechanics like Mikey and Bodsy etc offer a professional Megaflush service. That's enough for me as a knowledgeable enthusiast Thumbs Up If they need advice from a Chartered Biologist then I'm their man Rolling with laughter Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #517491 5th Jun 2019 10:34am
