![]() | Home > Maintenance & Mods (L322) > MY2010 Climate panel fit earlier? |
that panel is a single unit about an inch thick with sockets on the rear...i'm pretty sure its not plug and play though.. |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6819 ![]() ![]() ![]() |
I looked into this a while back, as my heater panel lighting is very dim.
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2246 ![]() ![]() ![]() |
yes I get that but I was literally going to buy is and take the front off and mount the old modules behind if that makes sense - but wanted confirm they'd fit first...
the 2010-2012 panel is one piece and all the knobs are integrated into it and does not have separate modules. |
yes got that Stan but I was literally going to take the black plastic off the front of it ant the buttons (not the module) do the same with the originals and then put the new buttons and black front on the old modules but before trying wanted to confirm the one piece would fit.. Current stable:
not sure if it could be separated dan..
hmmm .. I might buy one to check it out |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3853 ![]() ![]() ![]() |
They are interesting pictures, Thanks Stan,
loose connection mike?? |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16369 ![]() ![]() ![]() |
Dan, even if it were possible to do as you wish... JLR moved the switches around in the 09> so that would nt work in your favour either sir...
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 775 ![]() ![]() |
I’m curious, why do you want to do this? |
Yes I spotted that but as the buttons looks the same size I thought I’d just swap them around. Why would I want to do this? I prefer the black colour to the old fashioned grey - I’d also spray the screen so it would look a lot more modern up to date Current stable: 2006 BMW M6 2007 4.2 V8 S/C FF Gone: 2002 4.4 V8 FF |
