![]() | Home > Maintenance & Mods (L322) > 4 Wheel alignment - track rod arm seized |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6431 ![]() ![]() |
FFS!! LR Dealers ! |
smartkhan Member Since: 01 Jun 2019 Location: London Posts: 5 ![]() ![]() ![]() |
Would you recommend any mechanic in London for this job? |
Why not go back to your indie ? .
TJH1985 Member Since: 11 Feb 2015 Location: Nottingham Posts: 672 ![]() ![]() |
Just had the same on ours, I had just done the rear upper and lower hub bushes with new bolts etc so naturally sent it to be tracked at a very reputable place who do all the local performance garages etc. Same thing couldn’t adjust toe on the rear passenger side, seized and needed to be cut off - my other half reported they had had a real good go at it.
It seems my independent is not goo enough to do that work. I explained him the problem on phone but he was not sure what i am talking about.
In which case I would steer (excuse the pun) well clear of him in the future |
Rosco Member Since: 20 Jan 2012 Location: Beyond the wall. Posts: 2591 ![]() ![]() ![]() |
Like the pun Joe90, however for the pedants amongst us, to steer WELL clear of him he would need the alignment done, so can we just settle on steer clear of him, I thank you and apologies to the OP for moving off topic |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4349 ![]() ![]() ![]() |
Take it to www.rovertune.co.uk who will fix it right and first time |
nicksaab Member Since: 28 May 2013 Location: Wimbledon and West Wales Posts: 560 ![]() ![]() |
Plus one for Rovertune, or Millenium in Croydon - a mate has his Discovery looked after there Current Fleet:-
Talked to rovertune and they are not sure how long will it take so they can't give the estimated price. |
jim4244 Member Since: 31 May 2012 Location: UK Posts: 855 ![]() ![]() ![]() |
Can you not get underneath with a wire brush and a can of WD40?
kds2 Member Since: 30 Sep 2017 Location: lincoln Posts: 228 ![]() ![]() ![]() |
I think screwfix own no nonsense penetrating oil works better just dont go near it with a naked flame after you just spayed it. |
It’ll cost what it takes to fix. Had mine done. Less than £200 for supply and fit I think 🤔 Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory" 2025MY Defender D350 90 in Silicon Silver on coils 1974 Series 3 Lightweight = "Millie" Many, many other Landies over the years I use www.glenrands.co.uk Great independent specialist! -------------------------------------------------- |
