Home > Technical (L322) > Test pulse flashing on LED headlights
RaveRover
Australia 2005 Range Rover HSE 4.4 V8 Java Black
Hi.
Just fitted LED plug and play headlights to my 04 L322. Whenever I start the car I get both Headlights flashing.. which then stop after 15 seconds or so.
I've remedied a similar issue with my LED caravan / trailer lights with a resistor box.
Tried a similar thing with the headies and didn't work.
50 Watt resistor connected between pos and neg (earth) .. to give the load to the system..
Doing it right??? Dunno.. worked for the trailers, just not up front.
Thanx for any assistance in advance Smile
Thanx Matt (RaveRover) Once you've driven a Range Rover, everything else seems 2nd rate.. Eeeek I'm trapped for life.
1986 RRC Highline with offroad mods. Arctic Silver
2001 P38 HSE. Ardeness Green.
1995 RRC soft dash (beautiful car) Green.
2005 L322 HSE V8. - Current, most awesome car yet. And most expensive.
Post #518126 12th Jun 2019 8:53am
led headlights?? any pics.
Post #518129 12th Jun 2019 9:09am
RaveRover
Yep, I'll post some..
They're not changeover aftermarket assemblies.. just plug and play led bulbs.
Smile
Thanx Matt Once you've driven a Range Rover, everything else seems 2nd rate.. Eeeek I'm trapped for life.
Post #518138 12th Jun 2019 9:54am
UK Marine
England 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
Isn’t this hot or cold checking of the bulbs, I can never remember which one Very Happy
It can be turned off with the IIDtool. ______________________________
Simon
Range Rover Classic 3.5 efi - Gone
Range Rover Classic 3.9 efi - Gone
Range Rover Classic 4.2 LSE - Sadly gone
Land Rover 110 3.5 - Gone
Range Rover P38a 4.0 SE - Pleased it's gone
Range Rover P38a 2.5 DHSE - Just sold
Range Rover L322 4.4 v8 Petrol - Current
Post #518157 12th Jun 2019 11:26am
gj88
United Kingdom 2004 Range Rover Vogue Td6 Zambezi Silver
Yep, if you have one turn it off with IID.
If you don't have one, first task is to get one!
Post #518160 12th Jun 2019 11:43am
wayneg
Australia 2007 Range Rover Vogue SE TDV8 Java Black
I have Led bulbs in mine ( they are great). You have to fit both a load resistor and a relay to stop the flashing. The 2v test pulse won't be enough to trigger the relay, it will only switch on with a full 12v. I also have automatic white daytime running lights that switch to orange indicators that flow in the direction of the turn fitted inside the headlamps 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
1966 Series 2a with V8 conversion gone
Post #518166 12th Jun 2019 12:04pm
RobWheatley
United Kingdom 2010 Range Rover Vogue TDV8 Stornoway Grey
Oh, a video of the running lights please Very Happy
Post #518169 12th Jun 2019 12:26pm
Simply turn off the hot & cold monitoring in the CCF files... DO NOT use resistors as they create LOTS on heat and this is BAD! and even worse when the resistors burn out!!!
Post #518172 12th Jun 2019 1:01pm
RaveRover
Lol. I dont have a spare $700 laying around Laughing Once you've driven a Range Rover, everything else seems 2nd rate.. Eeeek I'm trapped for life.
Post #518441 14th Jun 2019 10:28am
I just let mine flash, never worried about stopping them.
Post #518446 14th Jun 2019 10:59am
gj88
That's not uncommon, my main point was that it'll pay for itself in the long run, and I wouldn't faff about with other solutions. My advice would be let them flash for a few months while you save, and then turn it off at the flick of a switch
Post #518478 14th Jun 2019 3:43pm
RaveRover
Short video of the flashing : Once you've driven a Range Rover, everything else seems 2nd rate.. Eeeek I'm trapped for life.
Post #518641 16th Jun 2019 4:21am
RaveRover
Short video of the flashing here Once you've driven a Range Rover, everything else seems 2nd rate.. Eeeek I'm trapped for life.
Post #518642 16th Jun 2019 5:35am
finchi
United Kingdom 2017 Range Rover Autobiography 5.0 SC V8 Carpathian Grey
If the monitoring is turn off using the IID, then I guess you lose the functionality of the lamp test with its obvious safety and convenience factors?
Post #518644 16th Jun 2019 8:01am
jaysta10k
United Kingdom 2014 Range Rover Vogue SE SDV8 Santorini Black
Hi I also have this issue I retrofitted halos in my headlights and I get the same a flashing for about 5 seconds when ignition is turned on. Where about in the CCf is the option to disable the hot and cold function and can disabling this cause issues? Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
Audi A4 2.7 TDI S Line Black Edition phantomn black
Previous Cars
Range Rover Vogue SE Overfinch Styling 22" Elara's full black stealth colour coded
Java black Range Rover sport 2.7 TDV6
Alaska white Range Rover sport overfinch 3.6 TDV8
BMW M3 Carbon Black
Post #518771 17th Jun 2019 3:56pm
