![]() | Home > Wheels & Tyres > Is this OK? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35861 ![]() ![]() |
whats the difference in tread depths??
jim4244 Member Since: 31 May 2012 Location: UK Posts: 855 ![]() ![]() ![]() |
You should never mix different tyre types on the same axle as each make of tyre has different grip, stopping and breakaway characteristics.
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Alicante / Andorra Posts: 8129 ![]() ![]() ![]() |
There’s no law against mixing tyres - except cross ply and radial and the former no longer exist really.
Eirik34 Member Since: 16 Dec 2014 Location: Norway Posts: 443 ![]() ![]() |
The spare is of the original 255/50R20 size, and due to that this is 2.3% less in diameter than the 275/45R21, I haven’t used this spare lately.
Boxbrownie Member Since: 19 May 2018 Location: FF gone now....FL2 i6 to play with Posts: 245 ![]() ![]() ![]() |
Except that, on the same axle...... otherwise it is perfectly acceptable to have differing sizes front to rear as in a staggered set up. David Please let me know if my comments upset you, I may wish to upset you again. |
The rear diff will of course handle a difference in diameter between the two rear tyres, but the question is if the 0.8% difference in circumstance on the rear tyres will cause wear on the center diff? The local workshop claimed that all permanent 4x4 cars need to have the exact same tyre circumstance on both axles to avoid wear or breakage of the center diff. Is this the case for L322 as well? |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1429 ![]() ![]() ![]() |
ownerinfo.landrover.co.uk (the online source for manuals, one can choose Norway too) for the 2017 model year says that tyres should ideally be replaced in sets of four, and if that is not possible then two the same on each axle. The choices available in the UK on that site seem the more recent models, you may of course be able to consult a hard copy manual for your own car.
