![]() | Home > General > 3.6 vs 4.4 TDV8 MPG |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35871 ![]() ![]() |
it depends on how you drive..someone might get 30/32 from a 4.4 whilst someone else less..
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 ![]() ![]() ![]() |
100% agree with Stan but i noticed an increase in mpg after changing to a 4.4 |
8810bigcat Member Since: 29 Apr 2013 Location: Home Counties Posts: 61 ![]() ![]() |
So far my 3.6 with mainly local journeys around 32ish, better on a motorway run and even around town 20%+ better than the Discovery 3 the RR has replaced. |
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 796 ![]() ![]() |
I’m running both and the 4.4 is definitely a good 10% better than the 3.6 but the 4.4 tends to get used on longer journeys. I rarely take any notice of MPG as I believe it is completely irrelevant in terms of running costs, even if my 4.4 was doing 50mpg it would still cost more to run as it is still depreciating rapidly but my 3.6 has virtually stopped. |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4351 ![]() ![]() ![]() |
4.4 will do more but it’s all relative |
Boxbrownie Member Since: 19 May 2018 Location: FF gone now....FL2 i6 to play with Posts: 245 ![]() ![]() ![]() |
Don’t let your relative drive it then |
Meant to say both my 3.6 and 4.4 were remapped 👍👍 2015 4.4 AB
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8786 ![]() ![]() ![]() |
having had both I can honestly say that I don't care...... |
grey17 Member Since: 31 Aug 2018 Location: ha6 Posts: 65 ![]() ![]() ![]() |
Thanks guys.
4.4 every time as it has the 8sp gearbox |
Craig is not wrong |
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 ![]() ![]() ![]() |
I came to fatty ownership from a Touareg and have just had the pleasure of towing my 2 tonne caravan for the first time. It used less fuel than my Touareg 32 mog plus around town and an amazing 25.2 mpg towing. There’s something special about doing the legal limit with the 2 tonne van on its back at a leisurely 1200 rpm. I can’t speak for the 3.6, I was advised the 4.4 was superior in many ways and I feel this was good advice. If you go the 4.4 route make sure the turbo drain mod has been done or budget £1000 or so to get it done. BMW i3 Electric Car
appj62 Member Since: 07 Aug 2013 Location: Cheshire Posts: 424 ![]() ![]() ![]() |
I guess you'll be put off by a SC then, whether 4.2 or 5.0 |
[quote="AJGalaxy2012"]I came to fatty ownership from a Touareg and have just had the pleasure of towing my 2 tonne caravan for the first time. It used less fuel than my Touare.......
