Home > Technical (L322) > Water build up - upper rear tail gate
uzp315
Does anyone else have this same annoying dribble from the rear tail gate. It seems to build up around the rear parking camera. It happens after rain, and water seems to sit and then slowly over some miles the water finally is all gone.
I have already replaced seals on the wiper, wiper motor and made sure neither wiper, nor motor are leaking any longer, and that the feed pipes are intact and good.
Post #518420 14th Jun 2019 7:52am
DrRob
Yep! Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #518433 14th Jun 2019 9:13am
yes its a design fault and normal....
.........as is the water coming in through the drivers open window when you use the front screen washers.... Twisted Evil
Post #518435 14th Jun 2019 9:32am
Woofster
Canada
Happens all the time! 2010 RR SC
2007 RR SC
Post #518476 14th Jun 2019 3:33pm
Bushy30
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
Why do I fear I will sound like Churchill the dog.................
Oooooooooooh yerst! Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
2004 FFRR Vogue 4.4 V8 with LPG
1997 P38 4.0 SE with LPG
1997 P38 4.6 Vogue with LPG
Post #518477 14th Jun 2019 3:38pm
DrRob
It’s a “feature” Rolling with laughter Rolling with laughter Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #518487 14th Jun 2019 4:59pm
Boxbrownie
United Kingdom 2008 Range Rover Vogue SE TDV8 Java Black
Yes, and perfectly designed to dribble straight onto the window switches......clever these LR chaps Rolling Eyes David
Please let me know if my comments upset you, I may wish to upset you again.
Post #518491 14th Jun 2019 5:39pm
Highroller
United Kingdom 2005 Range Rover Vogue SE 4.4 V8 Java Black
Very Censored annoying.
Post #518495 14th Jun 2019 5:48pm
uzp315
Ok, so not just me then. Somewhat relieved.
Has anyone figured out a way to stop it?
Post #518540 15th Jun 2019 7:26am
Rapiscan
England 2007 Range Rover Vogue TDV8 Santorini Black
I'm considering looking for something like a black plastic mini trough/L shaped profile say 10mm wide that can be cut to length and sympathetically affixed with black silicone down the full length side of the windscreen so that it channels the wipers efforts down it instead of allowing it run around the side window. Does that sound plausible? Or do those wind deflectors cure it? Rolling Eyes 2008 L322 Vogue 3.6 TDV8 in Java Black with parchment and Navy interior. 125000mls.
I used to be indecisive and have a split personality... but we are ok now...I think?
Post #518562 15th Jun 2019 11:49am
wind/window deflectors dont help...
Post #518564 15th Jun 2019 11:51am
uzp315
Rapiscan, you might find double glazing fitters/companies have something that would do the job.
I was thinking about filling in some of the voids under the rear spolier, large deployment of mastic carefully shaped might do the thing for the rear dribble, or at least reduce it a bit more. Obviously nothing porous that holds water is a good idea, so foam, sponge or anything like that under the rear spoiler is no good.
Post #518588 15th Jun 2019 5:21pm
Rapiscan
I know your talking about the rear window and I the side drivers one, my apologies, just thought slim black plastic profile fitted discreetly would prevent any water travelling around the sides especially with the window open, it's a massive design flaw allowing water onto the door electrics and astonishing LR haven't addressed it either? Confused 2008 L322 Vogue 3.6 TDV8 in Java Black with parchment and Navy interior. 125000mls.
Post #518598 15th Jun 2019 6:16pm
Woofster
Canada
Does anyone actually know why there is this build-up of water around the rear backup camera anyway?
What is exactly happening when it rains? Is it pooling up somewhere in the camera housing and then slowly trickling out? 2010 RR SC
2007 RR SC
Post #518640 16th Jun 2019 4:09am
kooky_guy
My upper tailgate seems to fill up with water which all comes rushing out down the sides when I open. Is this the sort of water collection that you're referring to? 2010 4.4 TDV8 Vogue SE
Post #518711 17th Jun 2019 7:46am
