![]() | Home > Maintenance & Mods (L322) > Factory tinted windows. |
Red Merle Member Since: 19 Sep 2016 Location: Cornwall Posts: 2158 ![]() ![]() ![]() |
It sounds like aftermarket stuff. It’s pretty easy to tell the difference; from the outside, you can clearly see the heated rear window elements, along with a funny “halo”, where the dot matrix print is around the edge of some of the windows. |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16369 ![]() ![]() ![]() |
Do you mean the rear side windows? They are laminated and suffer with a hazy/off colour appearance unlike the rest of the windows which are toughened. JLR have had this issue since the 2009-11 inception of double glazing... |
grey17 Member Since: 31 Aug 2018 Location: ha6 Posts: 65 ![]() ![]() ![]() |
FFRRWannabe Member Since: 19 May 2019 Location: Snohomish WA Posts: 39 ![]() ![]() ![]() |
My newly purchased 2011 suffers from this. Is it temperature related, I don't always notice the syndrome? It is only on the rear passenger glass. 2011 Range Rover Autobiography Stornoway Grey Storm/Jet Seats Center Console Storm IP/Topper Jet Grand Black Lacquer Finisher |
It’s the contrast between the rear door and third window that’s noticeable. I’ve added an extra layer of tint and it pretty much cures it |
Im afraid so sir... Right up to todays cars! ![]() |
Like this:
I had a test drive of a 2012 Westminster and the windows were perfect!
We’re the windows a combination of laminated and toughened glass as per the ‘405? |
I've no idea of the construction or layering involved in the glazing but, they were absolutely crystal clear with a neutral tint and the view looking out was perfect.
All FFRR’s since the 2009 digital dash facelift have double glazed side glass... So, all factory tints in this last TEN yr period suffer with this rear side window phenomenon...👍 |
