![]() | Home > My Range Rover > Wahoo, got my fatty today |
chugga90 Member Since: 24 Jul 2015 Location: Chilterns Posts: 159 ![]() ![]() |
Ewoke wheels are different pcd, so probably Sport version.
RobWheatley Member Since: 10 Mar 2019 Location: Yorkshire Posts: 37 ![]() ![]() ![]() |
Oh right, had a look on Ebay and only saw them wheels as Evoke, makes sense as sport wheels though |
Piet Member Since: 22 Mar 2017 Location: Maasdam Posts: 199 ![]() ![]() ![]() |
A 2008 SE should have bluetooth already Rob.
Had to work today (in the van) but did have a little play lunchtime , the FBH remote arrived, paired that and it seems to work fine, its too warm for the heater to kick in but it does bring the fan on for ventilation, might be cold enough in the morning to try it on heating.
rich89 Member Since: 05 May 2013 Location: United Kingdom Posts: 295 ![]() ![]() ![]() |
Check each parking sensor individually because if one fails, the whole system fails.
Are the fronts the same as the rears? I was thinking I could swap them over then see if the rears work when in reverse or does that bring the fronts on too?
finchi Member Since: 25 May 2017 Location: Hampshire and Cheshire Posts: 120 ![]() ![]() ![]() |
Regarding the parking sensors, if any one sensor, front or rear fails then both front and rear functionality is lost. So to fault find by elimination will require an additional parking sensor.
tb10 Member Since: 17 Feb 2015 Location: Bromsgrove Posts: 343 ![]() ![]() ![]() |
FYI, to check each parking sensor you can either listen to each one and you will hear a fast ticking or put a finger on the sensor and feel the sensor pulse. The wires are very thin so it is possible that one has broken. It’s a very worthwhile exercise to do as mine didn’t work for a number of years and when I got them working it was like having a new car as I could park in more spaces!!
Finally cleaned and polished
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 ![]() ![]() ![]() |
Very nice |
telly-addict Member Since: 22 Mar 2019 Location: Morayshire Posts: 140 ![]() ![]() ![]() |
mmm nice! |
Navydoc Member Since: 01 Jun 2014 Location: Perth Posts: 81 ![]() ![]() ![]() |
Looking good! Your alloys are RANGE ROVER SPORT 2009-2013 - 20" DESIGN 2 by the way 👍 |
Well the DVLA are very quick these days, less than a week and I have my log book already |
francy Member Since: 30 Jul 2012 Location: northwest Posts: 82 ![]() ![]() ![]() |
very nice shinny |
