![]() | Home > eBay & Bargain Spots > 7 seat conversion bin bargain |
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2236 ![]() ![]() ![]() |
Granted they need a bracket and belt but this could be had for under £100 if you know what you’re doing item no eBay Item No. 123798031835 Current stable:
I ended up doing a low ball offer and got them- can the brackets not be fabricated fairly easily? It look like a tube that mounts the back seat? Seat belts I was going to use generic lap belts? Current stable:
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3553 ![]() ![]() ![]() |
Dan also just to let you know this set up is a 3-point belt. Lap and sash I think they call it. In my pic the vinyl covered bracket is the high mount point for the sash. I wouldn't recommend you fit lap only.
Jut looking t your pic , seat belts aside I am just missing the two brackets to the right of the tape measure - I’m sure they could be fabricated if someone would be kind enough to measure them |
Look at the the two ebay pix above, There are five pieces (excluding belts).
This one off ebay shows it pretty well
Thanks - I have checked the laws and safety and I think I’m going to go with lap belts as unless you have a high speed crash in reverse they will pretty much be as efficient and you are the wrong way round. I don’t suppose in that case you would be kind enough to take a couple more close up pics of the two brackets that hold the seats to the back seats with the tubes? Even better would be some measurements I can fabricate some then. Thanks! Current stable:
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35729 ![]() ![]() |
if you get rear ended wont whoever is sitting in those seats smash their faces on the rear window..?? ... - .- -.
If they are loose you would but I have sat in the back and even if you are a giant if they are tight there is no way you’d hit the glass unless the hit you so hard the glass came to you but by then you’ve got bigger problems like your legs! Current stable:
