Home > Technical (L322) > Parking ECU
andrewcooke1720
Ireland 2012 Range Rover Westminster 4.4 V8 Barolo Black
Parking ECU
location, location, location
can anyone tell me where she is so i can check connections etc,
not working and no light on the center console.
is it a swap job or do i need a code breaker?
Post #51882 25th Feb 2011 5:22pm
looking on rave , it seems to be in the off side rear cubby hole next to the fusebox..... ... - .- -.
Post #51884 25th Feb 2011 5:27pm
Nickj
2003 Range Rover Vogue SE 4.4 V8 Java Black
Yes, on the opposite side to your audio (right as you look at back) take side cover off and its tucked away behind everything ( you can't see it to look at). Two nuts to unscrew and then pull it up. It will be a box with probably three block connectors going into it. think mines up the duff also but not found cheap replacement yet although i get lights and a long beep to say theres a fault. No light at all ? Fuse? power?
Post #51897 25th Feb 2011 7:06pm
andrewcooke1720
no fuse in slot 6 its a 5 amp jobby . replaced, light comes on as does an audible warning, ....... neither of which go off ... now i know why the fuse was pulled...
replacement ecu 85£ on eBay but recon i might have a sensor problem. time to pull the fuse again unless someone has any suggestions.
cheers Thumbs Up
Post #51956 26th Feb 2011 2:39pm
Nickj
I've just bought one of these ( see link at end of thread)
http://www.fullfatrr.com/forum/topic3489-30.html
Will let you know if compatible and only £40 delivered Thumbs Up
EDIT-oops someone bought already!
Post #51963 26th Feb 2011 3:24pm
dan_uk_1984
There is info on the module replacement here:
http://www.fullfatrr.com/forum/topic3998.h...pdc+module
A search will also bring up tons of results as it's a relatively common problem.
The module itself is the same as various other BMW modules, again on the link above is a list of all compatible BMW part numbers. I paid £27 inc P&P.
D
Post #51965 26th Feb 2011 3:28pm
Nickj
Dan, do you think the module i've bought part no. ending 931 will be an ok replacement for current defunct module part no. ending 930?
Post #51978 26th Feb 2011 6:09pm
dan_uk_1984
Yes YWC000931 is the same as 930 but with updated SW I believe. It's in Microcat as the correct one Smile
D
Post #51980 26th Feb 2011 6:39pm
Nickj
Lovely. £39 delivered brand new seems a bargain then. hopefully it'll sort my PS as have non currently!!
Post #51981 26th Feb 2011 6:41pm
dan_uk_1984
Bargain indeed!
Post #51982 26th Feb 2011 6:45pm
