Home > Technical (L405) > L405 centre console side fascia removal |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16165 |
Pull it towards you when your sat in the drivers seat... Its on 3 or 4 slide clips sir |
30th Aug 2018 10:24am |
mbdj Member Since: 14 Jul 2010 Location: scotland Posts: 98 |
Perfect thanks |
30th Aug 2018 10:33am |
seanjmcgrath Member Since: 18 Jun 2019 Location: Meath Posts: 2 |
Did this simple procedure work?? do you not have to remove the trim surrounding the centre screen before pulling the aluminium strips forward ?? |
18th Jun 2019 8:15am |
RRVSE-2 Member Since: 06 Jun 2015 Location: Kent Posts: 41 |
It works - just needs a good pull. You might have to search for the clips though, mine stuck and had to use tweezers and a small telescopic magnet to retrieve them! Keith
18th Jun 2019 9:11am |
Thanks Keith, do I need to remove the trim that surrounds the centre screen.... or can I just pull the strips forward as you describe ??? |
18th Jun 2019 9:18am |
Just slide it towards you as straight as you can. Keith
18th Jun 2019 9:31am |
DrF Member Since: 30 Jun 2014 Location: South East Posts: 1241 |
18th Jun 2019 6:01pm |
