Home > In Car Electronics (L322) > Cluster info
A.Pires
Portugal 2002 Range Rover Vogue Td6 Zambezi Silver
Cluster info
Sometimes I hit the tight button on the cluster judo to see time, consumption etc. That's what I have done yesterday and all the info disapear getting blank. I hit the button again and appear "check control ok" then test nr. 1 until 21. But the initial info never more. How can I return to the original info?
Thanks all
Post #518896 18th Jun 2019 12:09pm
sounds weird...
try again after a couple of days ,it may have sorted itself out , or do a battery disconnection.. ... - .- -.
Post #518979 19th Jun 2019 9:27am
A.Pires
Cluster info
Thanks, I'll do that
Post #518984 19th Jun 2019 10:17am
A.Pires
Cluster info
No
I run all the tests and disconnect the battery and stiil the same.
The only thing is when I switch the ignition on "hdc inactive"
Post #518993 19th Jun 2019 11:19am
make sure the battery is ok..
....and after reconnecting the battery, did you turn the steering wheel fully left then right? ... - .- -.
Post #518994 19th Jun 2019 11:23am
A.Pires
Cluster info
Yes but still the same. Later I'll try with Allcoms
Thanks
Post #519013 19th Jun 2019 3:18pm
