Home > Maintenance & Mods (L322) > Oil drain plug torque
Rambles
2011 Range Rover Vogue SE TDV8 Stornoway Grey
Hello
As the wiki on how to do a 4.4 oil change is sub optimal without photos and other info, can anyone help with:
Size socket to remove oil filter....I think it is 32 mm
And torque settings for both oil sump plugs
Please?
Thanks
Post #519187 21st Jun 2019 6:42am
Baltic Blue
4.4 td v8 oil filter is 36mm, not 32. Torque setting is moulded in top.
I have never used the sump drain plugs, choosing to always suck it out.
Post #519192 21st Jun 2019 8:15am
nino_nino
same here, but I drain small pocket (red arrow) which is turbo oil pickup every 3d oil change. it is size 13mm and I tighten it by feel.
 2012 TDV8 Black Edition
2000 Disco. TD5
1975 series III
Post #519194 21st Jun 2019 8:47am
Baltic Blue
https://www.fullfatrr.com/forum/topic6052.html
Page 294...
Mike G reg 2.5VM Vogue Portofino red 1991- 1999
Post #519196 21st Jun 2019 8:54am
rjff
Rambles
If it's any help I bought this one recently' Ace Parts on ebay, Sealy 36mm low profile oil filter socket. sorry don't have a link, £5.75 delivered. Cheers
Richard
Gap IIDBT
Post #519203 21st Jun 2019 10:13am
Rambles
Thanks chaps. Maybe a pump is the way to go.
Any pump recommendations?
Would still like the drain plug torque settings if anyone knows them?
Post #519280 22nd Jun 2019 7:45am
Baltic Blue
My suction pump is a Draper Professional from Machine Mart.
I don’t have access to a compressor, so have always just used it with the integral handpump.
I comes complete with a selection of tubes for connection to various cars, but for the 4.4 tdV8 you only need use the basic tube which is fitted. Just make sure any pump you buy has a minimum tank capacity of 10 litres.
I highly recommend the Draper for ease of use. Just warm the oil for ten minutes before you start and it sucks it all out in a few minutes, absolutely no mess.
Post #519281 22nd Jun 2019 8:01am
rjff
Rambles
Hope this helps Thumbs Up
and you don't need the sun behind the suction pump to see the level, do you Mike? Rolling Eyes Cheers
Richard
Gap IIDBT
Post #519301 22nd Jun 2019 11:08am
