Home > Maintenance & Mods (L322) > Suspension air bag
saj2421
United Kingdom 2006 Range Rover SE Td6 Java Black
Suspension air bag
I have a leak in my drivers front suspension air bag
Is it a replacement job or can you repair them?
2011 vogue
Thanks
Post #519318 22nd Jun 2019 2:25pm
replacement..you could also consider the other side if its the same age... ... - .- -.
Post #519320 22nd Jun 2019 2:45pm
AJGalaxy2012
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Bonatti Grey
Definitely replacement, recommend island 4x4 for the parts, relatively easy job, I've just done mine. BMW i3 Electric Car
2012 Full Fat RR 4.4 TDV8 (now gone)
2006 VW Touareg 3.0 TDi V6
Post #519370 23rd Jun 2019 5:37am
Henda
United Kingdom 2006 Range Rover Vogue TDV8 Zambezi Silver
Make sure the two bottom bolts will come out ,
Had to garage mine as the bottom bolt was seized solid and needed heat , also easier to cut the drop links off and replace with new ones
But is a driveway job with basic tools Thumbs Up
Post #519377 23rd Jun 2019 8:19am
