![]() | Home > Technical (L322) > Vibration while stationary in drive |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7992 ![]() ![]() ![]() |
Having bigger wheels on doesn’t cause the problem, it highlights it. There is vibration there as the driveshaft runs through the sump....the higher aspect ratio/bigger sidewalls on the tyres used on 18 inch wheels pretty much mask it. Land Rover never offered 19 or 20 inch wheels on a TD6.
Paul thornton Member Since: 23 Sep 2017 Location: Lancashire Posts: 545 ![]() ![]() |
I had the same issue. Mine turned out to be an injector fault. |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1031 ![]() ![]() |
19” wheels were eventually approved for the TD6, but only with a revised engine management calibration to counteract the torsional vibration/oscillation issue.
jaysta10k Member Since: 24 Aug 2017 Location: Cheshire Posts: 299 ![]() ![]() ![]() |
Do we need to have this update then if running car on 22inch wheels Phil? Is this something only the stealers can update also.
