![]() | Home > Maintenance & Mods (L322) > Yes, I did buy a lemon |
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2947 ![]() ![]() ![]() |
So I just took the TDV8 for a full service and asked them to look at the restricted performance fault and the fluttering noise.
philip1972 Member Since: 16 Jun 2017 Location: Marval 87440 Posts: 527 ![]() ![]() ![]() |
Could be worse.
PaulTyrer Member Since: 22 Jul 2013 Location: Devizes, Wiltshire Posts: 1262 ![]() ![]() ![]() |
Could be worse!
Just had a quote to do the broken stud. £1200 all in. They said they will have it for three days.
chugga90 Member Since: 24 Jul 2015 Location: Chilterns Posts: 155 ![]() ![]() |
The manifold repair sounds cheap compared to when one had to be replaced on mine!
Paul thornton Member Since: 23 Sep 2017 Location: Lancashire Posts: 545 ![]() ![]() |
Definitely explains your fault anyway Andy, Diesel noise getting louder as you drive etc. Manifold expanding with the heat.
jaysta10k Member Since: 24 Aug 2017 Location: Cheshire Posts: 299 ![]() ![]() ![]() |
Hi Paul what was the outcome when you had symptoms of shudder etc was it an injector or wiring loom at fault.
Mine was an injector. I used an IID tool measure the injector values which showed an issue with injector number 1. I then tested the loom (easy to do with a multimeter) which was ok so swapped the injector.
Ah right ok did you measure the reads at standstill idle or at a steady drive. My reads seem ok at standstill but at a steady speed of 30MPH CYL 6 is showing between 8 to 10mm3 fluctuating where as CYL 1 to 5 read 655mm3. Also i get quite a bad shudder in reverse and the shudder is more noticable when driving under light throttle. Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
At tick over. Mine all read between -2 - +3, apart from injector number 1 which was +7.
Ok cheers Paul Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
The weird thing is, since it was serviced, it hasn’t faulted once! I saw 30mpg on a run as well. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16350 ![]() ![]() ![]() |
A lot of work as all the injectors need to come out to change the inlet manifold/rocker cover... Warranty will require new seals and pipes which run into hundreds more! Just be aware... |
