![]() | Home > Technical (L322) > 2008 L322 suspension fault |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2701 ![]() ![]() |
The suspension fault codes really need to be read before doing anything to avoid unnecessary expense investigating and replacing components. |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6424 ![]() ![]() |
But worth trying NOT lowering it, and see what happens. This may help with diagnosis. .
superted2008 Member Since: 26 Feb 2019 Location: Liverpool Posts: 11 ![]() ![]() ![]() |
I will stop lowering it and see how i get on.
I stopped lowering for a couple of days and still got the fault.
You should check for any leaks, but more likely the compressor has had it, you will have to do a time vs money assessment. You should be able to find a "barebones" compressor, which will save some money, if you are comfortable with a bit of dismantling and simple wiring. I could be wrong.... .
Macca Member Since: 04 Oct 2016 Location: Nottinghamshire Posts: 21 ![]() ![]() ![]() |
sounds like the compressor. |
Swithins Member Since: 22 Oct 2013 Location: West Malling Posts: 151 ![]() ![]() ![]() |
I had a similar issue last year. A red dot over one of the wheels and slow compression. Then total suspension collapse where car was driving on its wheels. Called my specialist who said height sensor. Less than £200 later problem solved with replaced height sensor. Current:
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16365 ![]() ![]() ![]() |
Put the car into off road mode, if the car achieves that mode and you don't hear a big hissing sound (as you open the hole that's leaking, usually covered by the bag being partially rolled over) then look at the wiring to all the height sensors (clearly visible through the wheel arch on off road height) Don't be afraid to give each wire a little pull!!! I often find broken wires that are only held together by the sheathing, but the wire inside had fatigued and snapped! |
I have looked a little further into this and I have come to a possible conclusion as suggested that the compressor is at fault. Shame really as it was only bought in 2017.
