![]() | Home > Maintenance & Mods (L322) > MOT standards |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3866 ![]() ![]() ![]() |
Brad,
Bradders Member Since: 03 Dec 2018 Location: Gods own country Posts: 417 ![]() ![]() ![]() |
Thanks Mike - i am waiting for a call from the garage to see what they think. They use an independent MOT garage as they don't do MOT's themselves.
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3982 ![]() ![]() ![]() |
Nothing wrong with having brake pipes covered in grease provided the pipes were in good condition when the grease was applied.
Thanks chaps. This confirms what the garage are saying too. |
All a bit pointless really . You should have see the state-of-the old brake pipes I took off my L322 Td6 Vogue.
How unreasonable of you Mike, bearing in mind these cars are designed for the rough stuff |
m@ttsFF Member Since: 12 Dec 2017 Location: Surrey Posts: 336 ![]() ![]() ![]() |
The advisory is due to the tester being unable to confirm the condition of the pipes under the grease. 4.2 SC - sold , now bought back
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1852 ![]() ![]() |
As above. MOT tester has to cover his arse, should a brake pipe fail, in a place that cannot be accurately assessed or seen... |
gettingold Member Since: 03 Apr 2018 Location: Wiltshire Posts: 287 ![]() ![]() |
My regular tester retired so I had to use a local garage. It was in getting tested and a mechanic came into reception and spoke with the receptionist. He said that he (the mot tester chap) wants to fail (another car)the car on bushes, but we only fitted them in Feb so we’ve encouraged him not to fail it. I won’t be going there again.
ur20v Member Since: 19 Feb 2019 Location: None Posts: 634 ![]() ![]() |
MOT testers can only inspect what they see and are not allowed to remove coatings etc, as mentioned above, they will sometimes put an advisory on something looking suspect to cover themselves which is fair as there a lot of dodgy ‘ fixes’ done to get a car through an MOT by owners and garages.
My main point is there is no consistency in testing standards and that has cleary been confirmed by others experiences. I havent greased them since last years MOT which made no reference.
When humans are involved you will always get different outcomes, even with the same human!
