![]() | Home > Technical (L322) > Egr thermostat leaking |
| SidewaysMatt Member Since: 24 Feb 2016 Location: Ledsham, Cheshire Posts: 173
So I could get a complete unit from euros in the morning - listed as BMW but looks the fella:
| jim4244 Member Since: 31 May 2012 Location: UK Posts: 855
It looks good to me buddy 👍
| nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3989
How to change the egr thermostat without removing the viscous fan etc. |
Thank you sir 👍 2004 Vogue TD6 - Remapped |
| jaysta10k Member Since: 24 Aug 2017 Location: Cheshire Posts: 299
What are the symptoms of this leak mate? Rough idle etc.... Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
"Check coolant level" displayed on the dash, and a little puddle of coolant on the driveway |
| MarshallW11 Member Since: 24 Jan 2019 Location: Ottawa Posts: 18
If you run into any troubles with that you could also just remove the whole EGR and EGR cooler assembly! Clears up a ton of space in the engine bay and simplifies things. |
| All times are GMT |
