Home > Off Topic > Removing oil stains from concrete
Rambles
2011 Range Rover Vogue SE TDV8 Stornoway Grey
Hmmm. So I got a few drips onto concrete. Tried to soak up as best I could....but stains still there.
Any thoughts on oil stains removal from concrete?
Thanks
Ps. If I get equally careless and splash some differential oil on my concrete, is the cleaning method the same?
Post #519498 24th Jun 2019 12:16pm
Baltic Blue
Domestos household bleach is as good as anything.
Followed by a scrubbing brush and hot water.
Post #519501 24th Jun 2019 1:01pm
BMG
United Kingdom 2002 Range Rover Vogue 4.4 V8 Bonatti Grey
Not sure about concrete, but don't imagine it's much different, but by Farther reports did a good job on his block paved driveway.
https://www.halfords.com/motoring/engine-o...y-clear-1l
Post #519502 24th Jun 2019 1:05pm
Anvil
Brake cleaner is also a good tip. Gets oil our of pretty much anything. Do a test on an inconspicuous part first though! Also Cat litter in a big spill. Sucks it right on up.
Si.
Post #519510 24th Jun 2019 1:42pm
Balloonengineer
Household Caustic Soda and a stiff brush, works a treat, will make your drive cleaner than the clean bits!
(its what the commercial oil removal products contain. Buy it in a hardware shop in granules and mix it yourself, or sprinkle over the stain and add a bit of water)
Wear gloves and glasses.
Best wishes
Glen Previously......
Series 1 80, Series 3 88, Turbo 90, 300tdi 90, 110's with 200, 300, TD5
TD5 Disco, Disco 3, 200Tdi Disco - probably the best vehicle Landrover ever made,
Now 3x FFRR, some would say I should have learned by now......
Post #520228 1st Jul 2019 2:13pm
You need a detergent to remove the oil/grease .
Post #520241 1st Jul 2019 4:47pm
jim4244
England 2005 Range Rover Vogue Td6 Zambezi Silver
Bicarbonate of soda mixed with vinegar.
Jim
Post #520244 1st Jul 2019 5:32pm
Boxbrownie
United Kingdom 2008 Range Rover Vogue SE TDV8 Java Black
Cats Censored and Badger vomit.......as good as anything else Rolling with laughter David
Please let me know if my comments upset you, I may wish to upset you again.
Post #520270 1st Jul 2019 7:50pm
chugga90
A neighbour once used Petrol and a box of matches.
There was a loud whompf noise and him running away in terror.
He solved the oil marks, but had other stains on his person Rolling with laughter Rolling with laughter
Post #520277 1st Jul 2019 8:45pm
