![]() | Home > Maintenance & Mods (L405) > Westfalia detachable tow bar for facelift model. |
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1197 ![]() ![]() ![]() |
You may get some info from P F Jones about this. They seem to be able to supply many towbar sets. Phone and ask, worth a try.
Nigelhirst Member Since: 17 Aug 2018 Location: Shropshire Posts: 9 ![]() ![]() ![]() |
I had one fitted 18 months ago when my deployable one failed. Peter Bowman in Bury did an excellent job 2 days before I set off on holiday.
Kasperss Member Since: 06 Mar 2019 Location: Manchester Posts: 23 ![]() ![]() ![]() |
Hi, do you have to remove bumper middle section to use towbar or you can cut out a hole inside. |
Mine had a deployable one, and the detachable one fits under the ‘flap’ in the centre section without modification. I believe there are different designs of flap though (and they are expensive -£35+++, and VERY fragile), so if you haven’t already got a tow bar, you might have to buy the towbar style flap.
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2705 ![]() ![]() ![]() |
It’s a replacement panel, will fire a photo up tomorrow for you ![]() |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8043 ![]() ![]() ![]() |
The deployable looks like -
This is with the detachable with the replacement panel. Once fitted, no need to fanny about at all:
where did you get your replacement panel from? Is this genuine land rover one? |
Plenty on eBay |
Got it from Dan , £30 ish |
Jamiehol Member Since: 26 Sep 2014 Location: Ipswich Posts: 230 ![]() ![]() ![]() |
From recent experience but with a current shape Q7 I understand that the supply of Westfalia bars isn’t great at the minute due to them moving production facilities this was feedback from both the local Indespension depot and PF Jones. |
pierre_l Member Since: 06 Oct 2022 Location: Geneva Posts: 6 ![]() ![]() ![]() |
I am not sure I understand - is it the original one or a specific one for westfalia? |
