![]() | Home > Technical (L322) > Todays 'Crap L322 design' moan |
Why are the subwoofer bolts NOT loctited? Do they think it's funny for them to loosen and fall out?
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3555 ![]() ![]() ![]() |
Might check my sub bolts now. |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4345 ![]() ![]() ![]() |
Where are the subwoofers so we can all check for loose bolts? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Bradders Member Since: 03 Dec 2018 Location: Gods own country Posts: 417 ![]() ![]() ![]() |
My design rant - anyone successfully changed the rear wiper blade ? Not a problem to get it to stay in the exposed position but unclipping the old blade is a 'mare. Seems a bit bonkers to remove the spoiler just to get better access to the blade.
Bradders - open the top tailgate when the blade is in mid stroke i.e. pointing at 6 o'clock. Then chuck a towel over the lower tailgate latch mechanism so it won't re-latch and start wiping again- much easier to change the blade then. Top tip - press boot button when blade at 8 o'clock and it will stop at 6...
I can get the arm to stay exposed but unclipping the old blade is the problem. The clip seems very brittle and easily broken. Current: FF Westminster money pit
